Phantom 4 Pro Remote giving random single beep.
926 11 2017-4-13
P4 Pro Birdy
Flight distance : 391237 ft
I have just upgraded to a Phantom 4 Pro with the cheaper remote that does not have its own screen. This remote gives a single sharp beep as frequent as every 30 seconds or as infrequent as every 20 minutes.
There are no error messages and all firmware is the latest versions. Everything has been calibrated than can be and there is no apparent reason for this single random beep.
I called DGI support and after being on hold for over an hour was told that he did not know why this was happening. So what do you do when DGI cannot tell you and there is nothing in the manual?
Has anyone else encountered this or have any ideas?
2017-4-13
PAP's eye
Flight distance : 1103599 ft
Not sure if it's normal or not, but I get those too..
never timed it through, I just figured it was part of the go4 problems
2017-4-13
dronist
Nope... Sorry... Try re-linking the remote, delete and reinstall the app and see hwat work.
2017-4-13
Cetacean
Flight distance : 2528264 ft
Aloha Birdy,
     One of the causes of a single beep is if you have not moved the controller stick for 4 or 5 minutes.  It is a reminder to turn off the remote controller.  It could also be something else.
     Hope this helps!
Aloha and Drone On!
2017-4-14
Cetacean
PAP's eye Posted at 2017-4-13 18:58
Aloha PAP's eye,
     See my post to Birdy, the OP.  It may or may not be his problem and it may or not be your problem.  But, it does happen.
Aloha and Drone On!
2017-4-14
P4 Pro Birdy
I have noticed it is the same beep you get when you touch the green AF square. It maybe related to AF.
2017-4-14
P4 Pro Birdy
dronist Posted at 2017-4-13 20:31
Thanks for the feedback. I tried both of those to no avail.
2017-4-14
P4 Pro Birdy
Cetacean Posted at 2017-4-14 01:02
Aloha Birdy,
Thank you. Aware of that thanks but not the cause. It is the same beep you get when you touch the green AF square.  I am wondering if it is related now.
2017-4-14
P4 Pro Birdy
Aloha PAP's eye,
Thank you for the feedback. Will look.
2017-4-14
dronist
P4 Pro Birdy Posted at 2017-4-14 17:49
It is the AUTO FOCUS beep. If you have it on AF, every time the drone is trying to AF itself it will do the beep...so this is normal behavior.
2017-4-14
P4 Pro Birdy
dronist Posted at 2017-4-14 19:08
I am sure you are correct and have concluded the same thimg.  I have been testing with AF turned off for the last 2 days and it has not beeped once. It is also a different beep and quite defined once you are aware.
I am quite surprised that DGI support did not think of this and that so few are aware. Someone needs to tell them for the sake of others.
Hopefully this post will be found by others having the same problem that are looking for answers.
Thank you everyone for your feedback. Greatly appreciated.
2017-4-15
dronist
P4 Pro Birdy Posted at 2017-4-15 13:48
That is why we are here...Helping each other learning something new everyday!
2017-4-15
