Odd issue, stops recording at file change
985 9 2017-6-1
CynicalZombie
Flight distance : 179813 ft
So I'm flying like normal and recording in 4K.  At about 9 minutes or so, the Mavic stops recording by itself and the red record button on the screen turns white.
I've seen this issue twice now within the last 2 weeks. What I've noticed is that around the 9 minute mark, the file the Mavic is recording to reaches the 4GB threshold and it creates another file to keep recording. Both times I've had this issue, it happened at that same timeframe.
I'm on the latest firmware.   This happened once with the newest version of DJI GO 4 and once with the previous version.
Anyone had a similar issue?  Any idea what's going wrong?
2017-6-1
Lobstah Mobstah
Flight distance : 1218379 ft
Did you use your Mavic to format the sd card or a computer?
2017-6-1
Lobstah Mobstah
I ask because FAT32 has a file size limit of 4Gb
2017-6-1
CynicalZombie
The Mavic formatted it back when I first got it.  I'm 80 flights in and this only happened on 2 flights.  Wondering if anyone has had the same issue.
2017-6-1
PimpDawg
Flight distance : 1204754 ft
I had a similar issue on my other drone - video would stop recording on it's own. Turned out to be a failing SD card. Replaced it and it works fine.
2017-6-1
DroneFlying
Flight distance : 10774613 ft
Did it only stop recording, or by did your gimbal do a little "dance" (pointing the camera at odd angles) and eventually seem to reset itself? If the latter then what you're experiencing is a known problem.
2017-6-1
CynicalZombie
It only stopped recording... I was able to start recording again soon after.  I've had that known problem too with the gimbal reset but only once with the previous firmware version.
2017-6-1
AndyP.
Flight distance : 3738274 ft
DroneFlying Posted at 2017-6-1 11:46
I just got the dance issue yesterday, curious what is it. or can i get a link to a forum post because it scared the hell out of me when it happened *imagines cleveland's scene when we falls out of house in bathtube*
2017-6-4
DroneFlying
AndyP. Posted at 2017-6-4 14:36
Here are some examples that I believe may be the same problem you described. The first one is the very earliest incident I remember hearing about, so it's been happening since at least January:
Scary Mavic Moment 1/3/2017 HELP!
Mavic Pro Problem - Loss of Video and Gimbal Control During Flight
Gimbal Calibrating Mid-Flight Defect/Bug?
2017-6-5
AndyP.
DroneFlying Posted at 2017-6-5 13:22
those are the exact issue i had, haven't had it since though.
2017-6-6
