Ipad Mini?
2153 27 2018-3-7
Sproknok
Can I use Ipad Mini on mavic air? do I need LTE or just Wifi Mini?
2018-3-7
PS013
Flight distance : 3579409 ft
I use a Mini 4 WIFI only
2018-3-7
Sproknok
PS013 Posted at 2018-3-7 14:25
Thank You!
2018-3-7
PS013
you can also search the forum, as this topic is coming quite often
https://forum.dji.com/forum.php? ... &fromuid=940640
https://forum.dji.com/thread-104774-1-1.html
https://forum.dji.com/thread-129979-1-1.html
https://forum.dji.com/thread-102425-1-1.html ...
Best way to search the forum is to go to Google and enter  "Site:forum.dji.com" and your keywords
For example  :   site:forum.dji.com Ipad Mini WIfi mavic air
2018-3-7
Hi there, may I know which generation do you refer to? Please note that the first generation is not on the support device list which means it is not compatible with DJI GO 4. Please refer to the supported device list below. Hope it helps. devide support list.png
2018-3-7
Bigplumbs
Flight distance : 620164 ft
Ipad Mini 4 is very good If you want to use the gps features of the mini 4 you will need the LTE version as the gps is part of the phone chip. You donot need a contract or phone service though
Also it will fit in the arms of the controller
Dennis
2018-3-7
PS013
Bigplumbs Posted at 2018-3-7 23:05
If/when I need that feature, i use a Bluetooth gps with my mini 4 ( Garmin glo ). But 99% of the time, this is not needed for me
2018-3-8
Wyke
Flight distance : 33166 ft
I've used my WiFi-only mini 4, which advantageously fits in the holder quote nicely. (However recently bought a Crystalsky 5.5", which doesn't but the screen is amazing)
2018-3-8
Sproknok
DJI Thor Posted at 2018-3-7 22:32
Hi there, may I know which generation do you refer to? Please note that the first generation is not on the support device list which means it is not compatible with DJI GO 4. Please refer to the supported device list below. Hope it helps.[view_image]
the 4th generation, and also can i use the USB cable connector from controller to connect to iPad? Thanks!
2018-3-8
Sproknok
so wifi is not enough? good thing you said that im about to get the Wifi Ipad Mnin4. Thanks!
2018-3-8
Sproknok
PS013 Posted at 2018-3-8 05:53
Thank You!
2018-3-8
PS013
Sproknok Posted at 2018-3-8 07:08
Yes
However, the small cable that comes with the Mavic Air is too short. So you will have to use another one that  you can connect or on the side ( micro usb ) or a the bottom of the remote ( tradionnal USB plug )
2018-3-8
Please refer to the answer on 12#, the cable that came with the RC might be too short to connect a tablet, you can use your device's original cable for connecting. Please note that you need to unplug the left cable when connecting to the bottom port.
2018-3-8
Sproknok
PS013 Posted at 2018-3-8 07:18
Yes
Thanks a lot!
2018-3-9
Sproknok
DJI Thor Posted at 2018-3-8 22:24
Thanks a lot!
2018-3-9
Sproknok
Thank You!
2018-3-9
Sproknok
Yes
Thank You!
2018-3-9
Sproknok
so how about the GPS issue?
2018-3-9
Sproknok
PS013 Posted at 2018-3-7 14:30
https://forum.dji.com/forum.php?mod=viewthread&tid=112387&fromuid=940640
Thank You!
2018-3-9
Sproknok
Thanks for the info.
2018-3-9
Sproknok
Thanks Dennis!
2018-3-9
fansaf90809b
iPad mini 2 works but screen was crap in dAylight. Use my iPhone X
2018-3-9
Sproknok
RE: Niagara Falls?
Can someone give some advice if I can fly my mavic air in Niagara Falls? thank you!
2018-3-16
nywrecker
Flight distance : 832421 ft
Hi Dennis, how do you fit the iPad Mini to the AIR remote control?
I tried doing it on mine and the Mini is at least 3/4" wider than the fully extended arms.
2018-3-17
Mikem691
Flight distance : 247474 ft
nywrecker Posted at 2018-3-17 05:38
It will fit if you open the holders all the way on an angle. I have a video on this. Fits like a glove!
2018-3-17
JakeS
Flight distance : 7287871 ft
you can do it exactly like this just take out the little plastic square that holds the cable in normally as well
The mavic Pro and Air remotes are exactly the same size
2018-3-17
jcgoobee
Flight distance : 476119 ft
Of course you can, still use DJI Go 4 app anyway, LTE is not necessary. I've been using my iPad Mini wifi and works great.
2018-3-17
nywrecker
Mikem691 Posted at 2018-3-17 06:39
https://www.youtube.com/watch?v=I0rmxlhBOWw
Excellent.
I will give it another try.
Thanks!
2018-3-17
