Developer_Mode
Bartiflier Posted at 2018-3-17 15:57
Oops, missed that bit. Looks like a problem gimbal. Any weird or loud buzzing noises if you tilt the aircraft to extreme angles like you do during an IMU calibration?
Try the alternative gimbal balance method, where you balance the aircraft on the back arms/motors (take props off) so the gimbal points upwards. It will level itself to point forward, then calibrate. If that works, do it again on a flat surface as usual.
I just did that and it does not work.
P.S. Yes, it sounds bad ... Phantom 3 Pro is different, but it does not do these horrible things |
