Out of range? Auto RTH?
4208 29 2018-3-26
djiuser_q64BOA5L3qn5
China
If my Mavic Air lose contact with my controller for, say, 30 seconds, will it automatically RTH?
If not, DJI needs to add this feature.
You will keep so many of us happy that we won't lose our beautiful machine!
2018-3-26
JJBspark
Flight distance : 12566335 ft
Hiya, best advice is RTFM.
But in anwer to your question ; yes it will return home when is looses the connection. (it just happend to my MA today :-)  )
cheers
JJB
2018-3-26
Bekaru MP UAV
Flight distance : 15513100 ft
as jb spark says below - however do check your settings also to ensure that signal loss is set to RTH and not set to Hover (this is from a mavic pro pilot - not sure if air is the same)
2018-3-26
QuadKid
Flight distance : 482349 ft
Yes the MA will initiate Failsafe RTH if it looses signal for 3 seconds or more using the controler and it will initiate Failsafe RTH if the signal is lost for 30 seconds or more using WiFi.
2018-3-26
Phantom Help
Flight distance : 228255 ft
RTH is automatically initiated three seconds have the remote controller disconnects from the Mavic Air.
2018-3-26
China
Thanks expert MA colleagues, that's comforting to know! The craft is so small that it's easy to lose sight of it when distracted, especially when going around an area of LOS and Loss of Signal....
2018-3-26
Wachtberger
Flight distance : 261509 ft
Please read the manual if you want to enjoy your MA for long: https://dl.djicdn.com/downloads/ ... 20Manual%20v1.2.pdf
Then check your DJI GO 4 settings. You have several options for what you want to happen in case of signal loss!
2018-3-26
chiplifter
Flight distance : 745180 ft
Wachtberger Posted at 2018-3-26 06:59
Please read the manual if you want to enjoy your MA for long: https://dl.djicdn.com/downloads/Mavic%20Air/20180305/Mavic%20Air%20User%20Manual%20v1.2.pdf
If I might add, check the settings again after app or firmware update. It might happen settings will be reset to default values.
2018-3-26
Wachtberger
chiplifter Posted at 2018-3-26 07:57
Absolutely vital to do that, thank you for adding it!
2018-3-26
chiplifter
Wachtberger Posted at 2018-3-26 07:59
you're welcome.
It would be nice if @DJI made a save/restore feature for setting-preferences. After update I often forget to  set one of the many settings (mostly camera settings btw) to my preference.
2018-3-26
Wachtberger
chiplifter Posted at 2018-3-26 08:06
you're welcome.
Excellent proposal, you should send it to DJI directly or open a new thread "Feature proposal" for it as otherwise it might go unnoticed by those "in power" here ;-)
2018-3-26
chiplifter
Wachtberger Posted at 2018-3-26 08:12
And here it is:  https://forum.dji.com/thread-142007-1-1.html
2018-3-26
DJI Diana
Flight distance : 2408 ft
you're welcome.
Hi chiplifter, thank you for your suggestion, I will forward this proposal to our engineers. Hope more functions will be available in the future.
2018-3-27
Acenspades
RTH works when loss of connection.  Happens to me all the time. i can't go 300m without getting LOS and it's returned back it's static starting point every time.
2018-3-27
fansf77370fb
Flight distance : 1008924 ft
When you are flying turn of the RC and see what happens.
2018-3-27
Fantasia
Vietnam
RTH will works well if GPS signal >15 (my exp) and without strong wind and distance your AC <300 meters (at least 40% battery)
2018-3-27
China
Thanks! I've read the manual now and have confidence in RTH!
2018-3-28
cspain
Flight distance : 662644 ft
Acenspades Posted at 2018-3-27 06:37
Are you in a heavy urban area - 300 m is not far at all. One thing to try is putting your phone in airplane mode as its wifi and bluetooth could interfere with the Mavic RC signals.
2018-3-28
Acenspades
cspain Posted at 2018-3-28 11:00
yes,
My point of reference for a heavy urban area is right in the middle of Los Angeles.
I'll try airplane mode.
2018-3-28
China
DJI Diana Posted at 2018-3-27 00:23
Hi Diana, why isn't APAS automatically activated? Seems to me that it should be on by default and then rather let the pro's turn it off if need be?
It's one of several features that sets the Air apart from its competitors.
2018-4-4
DJI Diana
djiuser_q64BOA5L3qn5 Posted at 2018-4-4 04:28
Yes, it's a special feature of the Mavic air. Thank you so much for your suggestion, I will forward this proposal to our engineers, they will improve it in the future if possible.
2018-4-5
fansfe86a921
Flight distance : 578701 ft
I had two RTH on my Mavic Pro upon lost of signal.  But typically, the signal is lost because there is something in between me and the aircraft and block the signal (e.g. a building).  Both time when it initiate RTH due to Lost of Signal, I worry that whether the aircraft will clear the obstacle.  Luckily, both time are ok, but just a few meters above the obstacle.
It is best not to allow the lost of signal to happen.  When the signal is low, it is time to orient yourself properly, or start the return.  RTH is only a safety net.
2018-4-6
Bill B
Flight distance : 319245 ft
Please make sure you set your RTH altitude to the area you are flying in. Be sure your Home point is out in the open, and set before you take off. I can tell you from experience that it will indeed RTH after disconnecting. My Mavic Air is Junk, all it does is disconnect from controller all the time, and RTH. So make sure you have the settings right. I have owned 4 DJI quads (flamewheel 450, phantom 3 Advanced, Mavic pro, and now the Mavic air.) I have been flying these things for years with tons of air time, Never have I had more problems and disconnects than with this latest dissapointment, the MA.
2018-4-6
DroneDriver
Flight distance : 1164226 ft
djiuser_q64BOA5L3qn5 Posted at 2018-3-28 04:38
Thanks, now people in China can rest easier.
Would you buy a gun, without knowing how it works, take it out and shoot it all around you in all directions and then ask other gun owners if this thing will kill people?
I bet, yes.
2018-4-6
DJI Diana Posted at 2018-4-5 23:06
Finally Why don't DJI  put a solar panel into all drones?
2018-4-6
DroneDriver Posted at 2018-4-6 01:50
My! My!
               Your completely unneccessary reply informs me that you are a self-ingratiating person who likes to belittle people who don't have as much knowledge as you do.....about CERTAIN things of course! You think that your smarmy retorts will make people appreciative of your self-iindulgently presumed intellect?
I admit that I don't know everything there is to know....nor will YOU ever know everything there is to know about everything.
But, you have NO idea of where and under what circumstances I have flown my Air and your assumptive parallel between a drone and a firearm I find most most perturbing. I don't need the comfort of a gun to protect myself in most countries that I visit or live in.....seems like you do. Should I wonder why?
Naaaaa!!!!!
I've set RTH on the next bullet you fire, DroneDriver!
Aimed, most precicely, at your ignorant and arrogant arse!
2018-4-6
DroneDriver
LOL!
It took you a mouthful to answer a simple statement and proved me right on the mark. LOL ...and the point went right over your head. No,  you proved the ignorance with your opening remarks. Look it up, the meaning, you really should.
Me, arrogant maybe. knowledgeable, yes. Educated, yes. Licensed private pilot, yes. Safe drone pilot, absolutely. Accomplished photographer, you bet. Licensed gun owner, second amendment guaranteed. All because I wanted to be all of those things and more.
Young touchy millennial, NOPE.
It ain't arrogance if you can pull it off, my new friend.
2018-4-7
DroneDriver
DroneDriver Posted at 2018-4-7 13:50
LOL!
And to think,  FRIEND is the only name that I called you.
2018-4-7
DroneDriver
djiuser_q64BOA5L3qn5 Posted at 2018-4-6 04:01
A solar panel large enough that could generate enough power to fly or even assist the power source to fly is not possible using existing technology. The size/weight required would overcome the power generated.
Charging a MP battery takes about 1 and a half hours, using about three amps at the beginning. Current solar panel technology would require a more complex and costly system just to charge at the same rate.
Good idea, though. Keep asking questions.
2018-4-8
KeithG
DroneDriver Posted at 2018-4-8 03:13
The idea is not to fully charge the battery, just to extend the flying time when in use. Modern Solar-chargers are very light.
2018-4-10
