Aircraft out of range warning
1039 7 2018-10-26
Big kevo
Flight distance : 6614 ft
Hey guys I bought a refurbished p3A and I took for first flight and left it on beginner mode , but every now and then it would say aircraft out of range is this normal as it is only 30m away
2018-10-26
Mark The Droner
Flight distance : 2917 ft
See post #4 and post #7:  https://forum.dji.com/thread-118223-1-1.html
2018-10-27
Nebuchadnezzar
Flight distance : 3462946 ft
2018-10-27
Nebuchadnezzar
Big kevo just turn off beginner mode , Fly Safe and Enjoy
Welcome aboard
2018-10-27
ALABAMA
Flight distance : 10442687 ft
It just wants to stay close to ya, lol,
2018-10-27
Hi Big kevo, thanks for reaching DJI Forum. Sorry for the troubles you had recently with your aircraft. Let me help you with this. As Nebuchadnezzar is saying, that is correct. You may be at the Beginner Mode. Kindly check the photo provided at post #3 for your reference. In Beginner Mode, aircraft will only fly at restricted speed within a radius of 30 meters around the Home Point, and the motors of aircraft can not be start if GPS signal is not strong enough. Set Max Flight Distance, it is recommended to set the maximum flight height within 120 meters. Comply with local laws and regulations when flying an aircraft at a height higher than 120 meters.  Maximum value we can set is 500 meters. (for some product if are controlled by mobile device directly via Wi-Fi, this value can't be changed, for example: Spark, mavic air) Enable Max Distance , when Enable Max Distance is turned on, the maximum flight distance can be set from 15 to 5000 meters. When it is turned off, there is no limit on flight distance.  When Enable Max Distance is turned on, the maximum flight distance for different products may vary, please refer to user manual for more details.  Should you have any concerns, don't hesitate to reach us. We're here to help you.
2018-10-27
Cetacean
Flight distance : 2528264 ft
DJI Gamora Posted at 2018-10-27 04:29
Aloha Gamora,
     Mahalo for the excellent response to Big kevo!  Your hard work here is greatly appreciated!
Aloha and Drone On!
2018-10-28
Big kevo
Turned off beginner mode and she’s all good, cheers guys.
Now I just need to learn to fly
2018-10-28
