P3P Does IPad mini reqire cellular service?
6649 20 2015-9-19
mslone
hello, I have a question, it may be dumb but I can't seem to find a clear answer....
I just purchased the Phantom 3 Professional and I have an I Phn 5 so my phn will not work... I hate to get a new phone when this one works great.... I was considering just getting a used or new IPad Mini to have a larger screen but my question is if I buy one new or used do I have to have a data plan and cellular tied to it and all that jazz.....? Or can I just get the iPad and download the pilot app through wifi at home and then use it with my drone? I'd like to have a dedicated iPad for the drone but don't want to add another monthly bill in the mix to just fly my drone...?
Can I get some clarification so I can make my desion?
Thanks!!!
Michael
2015-9-19
BayArea99
Flight distance : 197336 ft
I use a IPad Mini 2 WIFI only model. It doesn't have GPS so I purchased a Garmin GLO that connects through Bluetooth with the IPad Mini 2.  So with the Garmin GLO all the intelligent flight modes that require a operator GPS location works great including follow me, etc.  I have run it with the DJI GO and AutoPilot APPS.
2015-9-19
mslone
BayArea99 Posted at 2015-9-19 22:44
I use a IPad Mini 2 WIFI only model. It doesn't have GPS so I purchased a Garmin GLO that connects t ...
I will just be using this for my real estate photography biz, so will not need follow me... Etc
More of an up take some pics and a little video of property and done...
Not planning to make any epic Ariel films etc...
So what should I get for monitor? You telling me that I can buy a I pad mini and download the Pilot app at home and then go fly anywhere with my P3P with no data or service as a dead monitor just fine? The return to home and Drone Gps is managed in drone??? Is that correct?
2015-9-19
DJI-Dave
mslone Posted at 2015-9-19 20:57
Yes you can just get a iPad mini2 and be fine.
The return to home and GPS is done in the Phantom.
2015-9-19
RedHotPoker
Flight distance : 165105 ft
Definitely  you don't need a cellular service turned on, to utilize the device to fly your Phantom 3.
But only the cellular versions of iPad have GPS. IF YOU DON't need the ground station features, then you should be good to go.
Have fun, happy landings.
RedHotPoker
2015-9-19
UKPhantom 3
RedHotPoker Posted at 2015-9-20 07:29
Definitely  you don't need a cellular service turned on, to utilize the device to fly your Phantom 3 ...
I use an iPad mini retina (V2), Wi-Fi only and hence no GPS and so far it works fine. I have been assuming that there is a GPS receiver in the Phantom controller as well as the Phantom itself. I haven't tried the new features yet.
2015-9-19
RedHotPoker
Hi @UKPhantom 3,
Unfortunately, to enjoy the new features, you will need an iPad with Cellular ability, to have the built in GPS module.
Even though we don't have to pay for any cellular service, to ulilize this GPS functionality.
Yes you can fly your Phantom 3 just fine without it, but for the groundstation features to work, the GPS iPad is a required must.
RedHotPoker
2015-9-19
deanO Aussie
Can I hook my mini 3 to my phone a Samsung s6 via Bluetooth and use that as my gps for follow me?
2015-9-20
deanO Aussie
2015-9-20
deanO Aussie
Can I use my Samsung s6 as a gps hooked up to my iPad mini 3 set up via Bluetooth?
2015-9-20
-=RaM=-
I can use all the new features except follow me with no GPS, I have a Wifi only iPad Mini 2.
2015-9-20
quantor13
Most Important is: You are in need of an iPad Mini 2/3/4 or an iPad Air / Air 2 as minimum requirement for the DJI GO App... A mini 1 or IPad 1/2/3/4 will not work.... You don't need GPS as long as you don't want to use the extended flight modes.... You can cache the maps at home and then use it on site... But for Real-Estate Photography I think using the (gps based) POI mode would be very interesting for your customers... And a used Mini 2 with Cellular/Gps isn't that expensive anymore...
2015-9-20
mslone
quantor13 Posted at 2015-9-20 06:14
Most Important is: You are in need of an iPad Mini 2/3/4 or an iPad Air / Air 2 as minimum requireme ...
So if I was to upgrade to a new IPhone 6 Plus with cellular all options and features are available to me?
2015-9-20
SkySurfer
mslone Posted at 2015-9-20 14:17
So if I was to upgrade to a new IPhone 6 Plus with cellular all options and features are available ...
Yes
Making sure I was clear
2015-9-20
louie.bellaphot
Flight distance : 389741 ft
SkySurfer Posted at 2015-9-20 17:41
Yes
""I can use all the new features except follow me with no GPS, I have a Wifi only iPad Mini 2.""
The above post is what I thought too.  You just need Cell/GPS for follow me.  I use the iPad mini 2 wifi and blue tooth from my iphone for the maps.  Works perfect.
2015-9-20
m.friedl
Flight distance : 3 ft
Austria
@mslone,
i would recommend an ipad mini 4 or ipad air 2 both with cellular even you do not use cellular service.
Some resons why you should buy one of theese:
1) all mentioned ipad devices with cellular has an integrated gps plus barometer inside.
2) WiFi only Models does not have GPS Chip on Board !
3) iPad Air 2 and iPad Mini 4 do have Glonass Chip also included!
4) if you want to use Follow from Autoflightlogic.com there is an Option to use Barometer and dynamic Altitude !
So i would buy one of that ones
Mike
2015-9-20
rhayhurst
Flight distance : 904442 ft
m.friedl@a1.net Posted at 2015-9-20 21:23
@mslone,
i would recommend an ipad mini 4 or ipad air 2 both with cellular even you do not use cell ...
I was out yesterday with my P3 and iPad Mini 2 (iOs 9.0) and the screen refresh just became worthless.  I've had an issue with this in the past on a very hot day, but the weather was moderate yesterday and this time, the screen refresh was the worst I had encountered.
1) Can I modify 'Settings' to improve this.
2) Should i try to revert back to iOs8?
Thanks.
2015-9-21
m.friedl
Austria
Had same problem with overheating when i had the Sunshield over the Tablet for sunprotection for the screen.
Remove the Shield and the Heatproblem is resolved for 90% - also switch Hardwaredecoding to ON in Settings of DJI Go !
1) and 2) Before revert to IOS 8 i would try this.
Mike
2015-9-21
Sir Edward K
RedHotPoker Posted at 2015-9-20 02:11
Hi @UKPhantom 3,
Unfortunately, to enjoy the new features, you will need an iPad with Cellular abili ...
I have an iPad Min 2 WIFI only and I can use waypoints, and POI but I cannot use follow me nor do I have a need to (at least at this time.)   I download my map while connected to wifi.  And I use my phone's Hot spot to download maps to my iPad Mini 2.
You don't need the cellular version unless you want the follow me function..
2015-9-21
m.friedl
Austria
Well, after this Thread i would do the Step back to 8.4.1
Take a Look here: http://forum.dji.com/thread-31763-1-1.html
Mike
2015-9-21
mslone
I decided to just go ahead and upgrade my I phone 5 to the new I phone 6S Plus... Hopefully this solves all  issues... Cheers
2015-9-21
