Phantom 3 standard FIRMWARE 1.6.80 MISTERY
5155 48 2016-6-26
egconstruger
Flight distance : 26906 ft
Dominican Republic
A lot of people claim theres a problem with signal lost including myself ,    as shown in this video
a other few says it works perfecly...  somethign weird is they didnt even mention firmware 1.6.80  on their dji support team facebook page when it was released, but theres all other firmware for phantom 4, phantom 3 advanced/profesional    something very weird and also they dont accept it as a firmware bug or something,   is just to hard to believe all of phantom 3 standard owners having the same issue JUST after firmware update 1.6.80 WOW what a coincidence(THEY ALL SAY THE SAME THEY WERE ABLE TO GO 400+M without problem before)    I HOPE NEXT WE ALL WIN LOTTERY TOGETHER
2016-6-26
bwaler
Flight distance : 3314541 ft
It's definitely a bug. I've had all sorts of signal issues since the update that I never had before.
2016-6-26
darrin
Flight distance : 1004731 ft
been dealing with this situation and have downgraded, 1 5 7+ I just added new ARG 7khz antenna and getting better range..( not much) .. so it maybe a series of the P3S craft that have this issue..
but just for pointers..this video has a couple issues -- straight up is a no no and with trees and houses all around another way to kill a test..please try a field and report back! cheers Darrin
2016-6-26
egconstruger
Dominican Republic
darrin@proimage Posted at 2016-6-26 15:11
been dealing with this situation and have downgraded, 1 5 7+ I just added new ARG 7khz antenna and g ...
i myself have done 7 different locations and after the latest firmware ,1.6.80  it goes green and black, same error Please notice as shown in the video RC SIGNAL AND WIFI signal remains full bars, it goes signal lost without any warnings at all... thats the problem WE ALL HAVING i know flying just above AC is not good, but if that was the case i remember before it would give low signal warnring or interference warnings now it just from a sec to another goes PUFF signal lost.
2016-6-26
cloudycante
Flight distance : 558173 ft
Just got back from my first serious flight, and it cut out signal at 140mt and it RTH back. I was in the middle of a cultivated field, so there was nothing between me and the aircraft and I never broke visual.
I uploaded the logs to HT only to read that the signal was 100 score and I even hadn't minor signal errors, so why all of a sudden the signal broke?
I really would like for DJI to improve the DJI Go App and add some sort of scale to let you know in flight time how and how much the signal is gonna worsen, so you can even avoid to break it at all.
RTH is a nice function, but it should be the last resort, and I wouldn't wanna have an RTH every single time I flight over 150mt.
2016-6-26
billwish76
Flight distance : 175495 ft
Humor me put country your from some say faa ver has no issue and uk ver does
2016-6-26
billwish76
They want to limit fpv flight so lock out sig
2016-6-26
g.wilkens
Hi
I have the same problems with my P3 standard after the last upgrade i can not go higher then 35 mtrs we the signal is lost.
How can i downgrade to an earlier version??
Cannot find the firmware on the P3 standard page
2016-6-26
cloudycante
billwish76 Posted at 2016-6-26 21:23
I don't really know the version I got, but I am in Italy
2016-6-26
AGENCIA 360
Colombia
Tengo el Mismo inconveniente con mi PH3 Estándar, Me sube a 140 mts y pierde La Señal, Vuelve a ir a casa, de distancia Llega un 210 MST y Nuevamente se Devuelve, lo he volado en Diferentes Escenarios y va igual en todos, NECESITAMOS ALGUNA SOLUCIÓN POR PARTE dE DJI, Dentro de las Especificaciones this Que Tiene Un Rango de 500 mts. llamada de socorro
I have the same problem with my PH3 Standard , me rises 140 meters and lost the signal again go to home , away reaches 210 mst and again returned , I've flown in different scenarios and is equal in all , we NEED ANY SOLUTION bY DJI , within specifications it is having a range of 500 meters. S.O.S
2016-6-26
bradleybowers
Flight distance : 643360 ft
DJI need to sort this out otherwise they are going to annoy alot of people and end up loosing alot of customers. I am having the same issues related to signal, and that is with an Argtek antenna installed and flying in an empty field. I have downgraded the firmware, yet still, no luck.
2016-6-27
egconstruger
Dominican Republic
bradleybowers Posted at 2016-6-27 10:32
DJI need to sort this out otherwise they are going to annoy alot of people and end up loosing alot o ...
they say 1.6.80 was to make video downlink reconection faster in flight, but it just messed everything up, i dont say the real word i wanted to say because moderator close this thread, but they f*** everything! and they dont fix it.
1MONTH ALREADY
2016-6-27
DJI-Ken
Flight distance : 1515312 ft
First off, since you are flying directly above you are your antenna pointed straight out and not pointed in the air? The worst signal is when you have the tip of the antenna pointed at the aircraft.
BUT, if you notice your WiFi signal still shows full signal which would indicate an issue.
What you can do is send the aircraft in to be repaired.Several video samples have been sent to R&D.
2016-6-27
WolvesSi
Why no announcement from DJI? It appears hey took our money now don't care. Really annoyed.
2016-6-27
wmcvey
Flight distance : 904364 ft
billwish76 Posted at 2016-6-26 15:23
Link to thread that is taking a vote on this very subject.
http://forum.dji.com/thread-56271-1-1.html
2016-6-27
egconstruger
Dominican Republic
DJI-Ken Posted at 2016-6-27 11:08
First off, since you are flying directly above you are your antenna pointed straight out and not poi ...
DJI -KEN i gave up, i sent my drone to repair, BUT IM 100% SURE it not hardware problem, it was ALL GOOD at firmware 1.5.70 , now i have 2 weeks without a drone  # THANKS DJI (SARCASM)
2016-6-27
DJI-Ken
egconstruger@gm Posted at 2016-6-28 05:14
DJI -KEN i gave up, i sent my drone to repair, BUT IM 100% SURE it not hardware problem, it was AL ...
I am sorry about that.
2016-6-27
egconstruger
Dominican Republic
DJI-Ken Posted at 2016-6-27 17:16
what worries me is that Engenieers team dont have a solution yet , and 1 month passed and still nothing, not even a NOTE from dji in their Facebook page, they should know they did something wrong with all this people complaining over the same issue, do you know what i mean?
2016-6-27
KrasheR
Flight distance : 43799 ft
I have the same problem, when going on like 50+ meters, the DJI Go app is disconecting even if the signal between the pilot and aircraft is very stable... pls help
2016-6-27
DJI-Ken
egconstruger@gm Posted at 2016-6-28 05:25
what worries me is that Engenieers team dont have a solution yet , and 1 month passed and still not ...
All I can say is to everyone who experiences this is to send the aircraft in for repair.
2016-6-27
DJI-Ken
KrasheR Posted at 2016-6-28 05:32
I have the same problem, when going on like 50+ meters, the DJI Go app is disconecting even if the s ...
If after all the troubleshooting steps have been done and your watched the Best Antenna Practices video and you still experience issues then please contact support and sent the aircraft in for repair.
2016-6-27
cekabu
Flight distance : 9154 ft
Turkey
DJI-Ken Posted at 2016-6-28 00:34
Why you want to punish people who are using this where there is no DJI service? Sending it to you and receiving back with custom clearance will cost almost half of the p3s price which is unacceptable. Just inform how to fix it
2016-6-27
egconstruger
Dominican Republic
DJI-Ken Posted at 2016-6-27 17:34
yep, i sent mine for repair but can you atleast tell us what internal piece is failling? and aproximatly how much will it cost us? , just tell us no need for a precise answer just tell me mmmm it might be the 5.8GHz reciever board who overload or something similar so we can know how much the fix will be,
i have read 3 people who sent their drone to repair and they get it back fix after 2 weeks but DJI doesnt say what was wrong...
2016-6-27
DJI-Ken
cekabu Posted at 2016-6-28 05:40
Why you want to punish people who are using this where there is no DJI service? Sending it to you  ...
That's the only solution at this time.
You are free to wait and see if there is anything in a firmware update at a later time. I've heard noting of an update otherwise I would be telling users to please be patient and a firmware update is coming.
I know R&D is looking into it and that's the only information I have.
2016-6-27
KrasheR
DJI-Ken Posted at 2016-6-27 23:35
If after all the troubleshooting steps have been done and your watched the Best Antenna Practices  ...
Sending the 4 days old drone for a repair? This is nosense...
2016-6-27
bradleybowers
So, you'll repair a phantom that I've changed the RC antenna on?
2016-6-28
KrasheR
So does someone know the fix for it?? It's really annoying...
2016-6-28
cekabu
DJI-Ken Posted at 2016-6-27 23:46
You are free to wait and see if there is anything in a firm ...
As it is said above just tell the solution. Which part needs to be replaced? It may be a cheaper solution for those who have hard custom procedures than sending it to you for reparing.
2016-6-29
DJI-Ken
cekabu Posted at 2016-6-30 05:50
As it is said above just tell the solution. Which part needs to be replaced? It may be a cheaper s ...
It's not a user serviceable repair.
2016-6-29
darrenphillips1
Flight distance : 501913 ft
Read some of my post
2016-6-30
egconstruger
Dominican Republic
mmmm  so all phantom 3 standard board got damaged after firmware update? :O
2016-6-30
darrenphillips1
bradleybowers Posted at 2016-6-28 16:16
Read my posts and don't need to send RC
2016-6-30
darrenphillips1
egconstruger@gm Posted at 2016-6-30 20:55
No not anywhere near all
Each one needs to be checked individually to confirm the fault
2016-6-30
egconstruger
Dominican Republic
darrenphillips1 Posted at 2016-6-30 09:22
Lol its been 1 month, and no word from DJI  no solution, nothing My hope is gone for real......
2016-6-30
darrenphillips1
egconstruger@gm Posted at 2016-7-1 09:16
Contact support through this Dji go app online  with your claim number they will give you update of your claim progress
There is also repair progress inquiry options using your claim number on the first page of this forum
2016-6-30
cekabu
Turkey
darrenphillips1 Posted at 2016-7-1 04:38
Contact support through this Dji go app online  with your claim number they will give you update o ...
Does DJI pay you for your posts To tell people to send their drones back for repair and the customer service is really good? Or are you working for them? All of your posts are same just saying "thank you dji"
2016-7-2
WolvesSi
I've tried absolutely everything.. Downgraded firmware yesterday in the hopes it would resolve it to no avail. I've contacted DJI but it appears they think I'm stupid or something...
Any idea on turnaround times?
2016-7-2
WolvesSi
I also have an issue with my gimbal being around ten degrees off level every time I switch the drone on and  have to recalibrate it every time..
Any one else got this issue?
2016-7-2
daverower
Flight distance : 33570 ft
So dji-ken says its not a user serviceable repair. This means he knows what the fault is. Please tell us
2016-7-2
DroneToTheMAX
This is a MYSTERY to me! I have a stock Phantom 3 Standard, Stock Remote, and can get 2km/1.3Miles! I am sure my Phantom 3 has the latest firmware, because whenever I connect it to my device it doesn't say anything about updating the firmware, and once it did, when it asked me to update to 1.6.80. However, I have noticed that lately my drone has had trouble reconnecting the FPV signal if I fly far out, it takes like 5 seconds to reconnect. Not a problem I even worry about, but still a mystery. I will be getting the ARGtek mod soon, and am hoping for at least a solid 2 miles. But I for SURE am not updating my firmware, after all these issues for other people!
2016-7-2
