Jyunte
Flight distance : 2103150 ft
DJI Thor Posted at 2017-11-7 18:46
As far as I know, it would be useless to refresh the iOS system for this issue. When the GPS precision is insufficient, GPS signal weak will show on the app when one wants to refresh the current position as the Homepoint. The dot on the map indicates the position of the mobile phone. When the dot is red, the signal is weak. When the dot is blue, the signal is strong and the Home Point can be set.
Please try another mobile device which has GPS module, and enable cellular at that moment and see if it works.
At the same time, I will also report it to the engineers. Thank you for your feedback.
The home point is blue, in all cases.
The GPS Signal is not weak on the device - as indicated above, all other GPS dependent apps have no trouble finding and maintain my location (I have 2 terrestrial GPS mapping apps, and 3 aeronautical GPS mapping apps, and NONE of them have any issues... Only the DJI Go 4 app has trouble).
Many others have reported the same issue with the DJI Go 4 app.
I'm attaching a screenshot... It's from my GPS diagnostic app. I'm sitting at home, on my couch, not out in the open on the flying field, or on top of a hill (like I was this morning) with a clear view of the sky. As you can see, under the roof of my house, I have GREAT GPS reception. Outside, in the open, it's not going to be worse, it's going to be better.
