fans42c8019f
Flight distance : 5883 ft
Ok something is definitely amiss. After 5 days of no use on a full charge, here are the numbers:
Battery 1 (out of drone): 95% / 4 solid lights on both charger and drone
Battery 2 (in charger): 95% / 4 solid lights on both charger and drone
Battery 3 (in drone): 98% / 4 solid lights on both charger and drone
All are new, and all are updated to latest firmware.
It’s possible that Battery 3 shows more charge in the drone because it had never been used (vs the other two which has both been used once each). However, the fact that the charge is still in the high 90s / 4 full LEDS for each battery proves that the expected behaviour that has been communicated by DJI and others is not the realized behaviour, and further investigation on DJI’s side is warranted. |
