Raveneye disappointment
4720 15 2021-12-12
thsc
Austria
I was looking forward to this easy application and bought the pro bundle
but what a disappointment
been trying to get it to work all day yesterday
my equip etc:
- Sony A7 IV
- RS2
- Android 10 (Fairphone 3)
steps:
- connected the raveneye HDMI with the camera
- connected the com-port on the other side to the gimbal (bottom slot)
- connected the gimbal (top slot) to the Sony-Multi (also tried the usb-c to usb-c)
- updated firmware of the Gimbal to 1.05
- updated App to 1.4.10
additional steps i made on the camera:
- HDMI info OFF, to have preview on the camera screen too
- HDMI output from AUTO to 1080p (just to make sure)
- i can connect the gimbal to the app, everything works fine
- then i connect the raveneye through wifi with my phone, lights on raveneye green
- BUT then it says:
- 'gimbal not connected'
- and there's no preview or any camera info in the preview-screen of the app
- no Fimrware info or Deviices in the apps settings
- so no possibility to update Raveneye Firmware either
- (startup sequence, RS2 > Camera > Raveneye)
what's wrong with this product?
apparently i'm not the only one with problems..
thanks in advance if anybody has any tips
regards
thomas
2021-12-12
DJI Susan
Hi Thomas, thank you for reaching out, when using the Sony Multi cable for connection, RavenEye is supported. Could you please provide a video of your setup of the camera and gimbal for better assistance? Look forward to hearing back from you. 1.png
2021-12-12
AntDX316
Flight distance : 3394731 ft
I have the A7R4 and it works.  I don't remember the camera settings exactly.  Don't try to figure out how to get Aperture, Shutter, and ISO to show on the Raveneye.  I've tried everything and nothing works.  Others have too.
You need to connect the HDMI connections.  Use the Sony cable to USB-C on the RS2.  Connect the USB-C from the raveneye (other side like on the video I've made) to USB-C on the RS2.  Then it should work.  You can connect the USB-C from the Sony to the USB-C to the RS2 which is for the follow focus motor but instead would use to recharge the camera (not on video).
Also, if you've never had the update raveneye firmware update pop-up you need to do this.  Post #22
https://forum.dji.com/thread-234596-1-1.html
Disconnecting and reconnecting the cable from the camera to the RS2 fixes problems.  It's like this on the Ronin-S too when I can't get the record button to work.
2021-12-13
thsc
Austria
Hi Susan,
thanks for the reply!
first - regarding your picture - as mentioned in my post, i startup the setup as follows: Ronin > Camera > Raveneye
that's correct - right?
second: you asked for a Video - you get ... photos
the setup:
then i start up everything and the RS2 connects with the APP
and it tells me connecting the raveneye will disconnect the gimbal
i do that and connect the wifi from APP and raveneye
(to be continued)
2021-12-13
thsc
Austria
after connecting the WIFI it looks ok
but the preview monitor doesn'T come uzp automatically and when i click it it looks like this:
it shows the gimbal as disconnected
no firmware Info or anything
zero devices
when i disconnect the wifi again i can again reconnect the gimbal
and it tells me RS2 is connected to the raveneye - and i should connect through raveneye
i click ok and the gimbal is again connected but ofc without the raveneye
i hope this helps and maybe i'm missing something completely obvious
regards
thomas
2021-12-13
thsc
Austria
AntDX316 Posted at 12-13 01:39
https://www.youtube.com/watch?v=8i1Xs9gaSMM
hey - thanks for the answer
but that sounds exactly like i described what i do
all cables connected (except the usb-c for charging as you mentioned)
i have just posted a summary with pictures - maybe you see some error
i was pretty sure the A7-IV isn't the problem - but good to know
2021-12-13
AntDX316
thsc Posted at 12-13 01:56
Connect RS2 to app > Connect to raveneye at the bottom middle of the app > Log in w/ the Wifi code stickered onto the Raveneye then it should work.
2021-12-13
thsc
Austria
AntDX316 Posted at 12-13 02:00
Did you turn the Raveneye on and log into it?
as can be seen on the photos above, the raveneye is on and light is green
i'm also logged in with the APP
not sure what you mean with login into Raveneye?
2021-12-13
AntDX316
thsc Posted at 12-13 02:02
Did you remove the lens cover from the lens?  You need to check your settings in camera then maybe.  Did you upgrade the Raveneye firmware at least?
Also, did you ensure you are using the Sony cable?  Just because it fits in the port doesn't mean it's the Sony cable.  I think there are 2 different cables that have the same port.  The Sony one is a bit longer at the camera side.
2021-12-13
thsc
Austria
AntDX316 Posted at 12-13 02:03
hehe - i appreciate your help but you are joking right?
(as can be seen on the pictures above, the screen is black because it's not connected properly)
and i just realized a totally different thing regarding the forums
i can only see parts of your posts in the thread - and when i click reply it shows me your full post in preview
2021-12-13
thsc
Austria
ok, now that i replied i can also see your last question about the Firmware update
i already answered this in my initial post - as the raveneye is not connected there is no possibility ti update the firmware
and it doesn't look like you can update raveneye firmware without a connection through RS2
2021-12-13
thsc
Austria
and now your post is longer than before - did you edit it?
and yes, the cable is labelled "USB-C to Sony Multi"
2021-12-13
thsc
Austria
and yes - raveneye WIFI is connected as indicated by the green light and here:
2021-12-13
thsc
Austria
IT WORKS!
basically what i did - i just reinstalled the APP
could have guessed it before - but hey
i also got some (chinese?) error message, which i cannot read as stupid european
but it does work now
updating the Raveneye firmware now..
i guess maybe when updating the APP recentely to 1.4.10 something got messed up? no idea
2021-12-13
AntDX316
nice
higher focal lengths and high-speed activetrack will make it oscillate
2021-12-13
djiuser_MUj3JGuuC5lJ
I have the RS3 Ronin with the Raven Eye with the Sony a7siii camera and everything works perfectly including the aperture,shutter & ISO which I can control via my phones screen, you need to have Bluetooth on your RS3 and on your phone turned off. Make sure you go to the Ronin apps settings in your phone (iPhone) menu and turn off Bluetooth just for the Ronin app.
2023-1-25
