Active Track and RTH
2451 32 2022-6-15
HjxQRSeH5V58
Dear DJI, today I tried the Active Track function while riding a mountain bike.
Before leaving I set in case of signal loss with the remote controller not to do RTH but station on site so as not to have to return to the place of departure, even a few kilometers away to retrieve the drone.
However, I had not taken into consideration another matter: after having come a long way in Active Track, the drone's battery naturally discharged and Low Battery RTH began, making it fly away back to the starting point.
But what's the point of all this?
It is also not practicable to manually and continuously update the Home Point while pedaling or running.
Without the Low Battery RTH the battery could last for an additional minutes of Active Track.
Then It should be possible to set, in the event of a certain percentage remaining battery, an acoustic signal and station on site, as for the Failsafe.
Best regards
2022-6-15
enricorc_cz
Flight distance : 609390 ft
Czechia
Hello, so low battery RTH does not accept same setting as Signal loss RTH? I would expect it. I used ActiveTrack for many times, but never into battery low lever so it never happend to me. Would be very surprised when drone would take ride back to "home"    Hope they'll fix it...
2022-6-15
mluidjdi
Why not have the option to have it rth to where ever the remote is?
2022-8-3
The Saint
Flight distance : 5902228 ft
ultimately a rth triggered by a low battery can be stopped.  the dji drone is not the ideal tracking drone but it kinda works for the most part.
2022-8-3
HjxQRSeH5V58
The Mavic Pro released in 2017 had Dynamic RTH !!!
2022-8-3
Sean-bumble-bee
Flight distance : 15997 ft
Why would setting a disconnection behaviour change an RTH behaviour? Have you read anything to suggest that it does?
Even in the event of a disconnection, a failsafe setting of hover will end up with a low battery RTH unless the controller is moved back into connection with the drone.
With some DJI drones it is, I believe, possible to reset the home point whilst the drone is actually RTH'ing, did you try ?
Did you cancel the low battery RTH and reset the home point to bring it to you?
From what you have written it sounds as if you made the flight without knowing how the drone will behave and with out knowing how to take corrective action, if that is the case who is at fault, you or the drone?
2022-8-3
HjxQRSeH5V58
Who talked about disconnection?
2022-8-3
Sean-bumble-bee
HjxQRSeH5V58 Posted at 8-3 11:00
You did, indirectly. "in case of signal loss with the remote controller not to do RTH but station on site so as not to have to return to the place of departure"
But did you notice that I wrote "Even in the event of a disconnection", I did not say that a disconnection actually occurred.
The failsafe setting governs ONLY the immediate response to a disconnection, nothing else.
It is not unreasonable or unexpected to be caught out by unexpected behaviours. These things a complicated and often it is our expectations that are flawed not the drone's behaviour. Yes I have been caught out by such things but on rereading the manual I have, ever time, found that the drone behaved as it was supposed to and that it was me that was at fault. e.g. https://forum.dji.com/thread-270615-1-1.html
For this reason, especially were multiple behaviours are involved, I like to make trial runs in a safe place and see how things play out before I encounter them in a real flight.
2022-8-3
HjxQRSeH5V58
So you are saying that since the drone behaves as specified in the manual, the problem does not exist: it is up to us to act accordingly.
It's correct?
But the behavior I highlighted is an annoying problem, because if the drone does RTH during an Active Track with obstacle avoidance it risks hitting a possible obstacle that is above it, since, first of all (first problem), it would rise. at the set quota of RTH.
After that it would go to the recorded RTH point which could be quite far away from you (second problem).  DJI has always added new functions and new behaviors precisely to solve the various problems that arise over time.  In fact, in the Mavic Pro the Dynamic Home Point has been added in a later firmware.
I don't see what's wrong with asking for a possible different drone behavior in the RTH settings.
2022-8-3
The Saint
HjxQRSeH5V58 Posted at 8-3 14:28
It's correct?
i think part of your frustration is that dji hasn't completely thought it out primarily because the drone is not adept at tracking.  and unlike the skydio which simply won't crash into anything no matter what (for the most part), there's a lot to consider.  perhaps you are asking for features like this, not every company has a nicole to explain it so clearly; see if there is something here you might like:
2022-8-3
Sean-bumble-bee
It's correct?
I am saying that the drone behaved correctly and that it was your expectations that were wrong. As such the problem was yours.
There is nothing wrong in asking for new features and yes, I agree, dynamic home point would be a useful feature. But you asked "But what's the point of all this?"  I attempted to explain.
But a dynamic homepoint is already 'sort of available', manually, you could have stopped and possibly have reset the home point once you saw that drone was RTH'ing whilst the drone was RTH'ing.
If resetting the home point whilst the drone is actually RTH'ing does not work with the Mini 3 then you could have cancelled the RTH, reset the home point to your location and restarted the RTH.Did you try either of those?
Your comments mix together two entirely separate things, Failsafe/loss-of-connection behaviour and RTH behaviour. The low battery RTH was/is not Failsafe behaviour.
As for Failsafe behaviour including RTH to a dynamically updated homepoint, that raises an interesting question, where would the last recorded homepoint be?
Would you stop and wait for the drone to head for the last recorded home point or, if you continued moving, would you hope that the RTH would bring it back into connection?  Similarily, with regards to Low-battery-RTH, if that was to a dynamically updated homepoint would you continue to move whilst the drone was attempting to return to you? You might be moving further away from the drone...lengthening the flight to safety possibly too far.
2022-8-3
HjxQRSeH5V58
Sean-bumble-bee Posted at 8-3 18:34
You're struggling to justify the drone's behavior… ..if you're happy so much better for you.
Then you forget that in case of Low Battery the controller warns you acoustically and, therefore, it would be enough for the drone to stop where it is in order to easily recover it.
The improvements in drone functionality are always due to user feedback.
2022-8-3
Sean-bumble-bee
HjxQRSeH5V58 Posted at 8-3 23:15
I am not struggling to justify anything, the drone behaved as it should, if you did not know how the drone would behave then that is your fault, not the drone's.
2022-8-4
HjxQRSeH5V58
Sean-bumble-bee Posted at 8-4 00:29
In the use of a smart device, various automatisms are provided.  These automatisms should cover the various usage scenarios and the particular needs of the user.  In fact, in the case of failsafe, DJI has provided flexibility in the automation, letting the pilot choose the behavior of the drone.  The same thing should be done in case of Low Battery.  That's all.  The pilot is solely responsible for the flight and should determine what kind of automation should be performed.
2022-8-4
djiuser_437VUZ7BViXQ
Israel
mluidjdi Posted at 2022-8-3 07:27
that makes a lot of sense, I had the same thought myself
2023-5-7
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
The home point can be set anywhere. What prevents you from pointing to the end of your trip, and then start driving with tracking?
2023-5-7
HjxQRSeH5V58
If you had read carefully you wouldn't have asked this question.
2023-5-7
Drone.Hunter
Kazakhstan
HjxQRSeH5V58 Posted at 5-7 10:30
I carefully read, and your problem is close to me.
Since the drone cannot automatically update the home point to the remote controller. This is a workaround so that the drone does not fly to the beginning of the route when the battery is dead, but to where you are going. As the distance to the new point of the house decreases, the flight time increases and the drone may not turn on the return home mode due to a decrease in battery capacity.
2023-5-7
HjxQRSeH5V58
Drone.Hunter Posted at 5-7 18:20
The end of the route is a few dozen KM away from where I started.
It's not feasible.
2023-5-7
Burt37
Flight distance : 4009 ft
I reckon the option to fly back where ever the radio is as an Option without the need to stop an emergency landing it is a great idea...
2023-5-7
Drone.Hunter
Kazakhstan
HjxQRSeH5V58 Posted at 5-7 22:51
It's not feasible.
If such a long distance, then in any case the drone will not reach the finish line, even if the remote control is always the home point. So you were planning to pick up a drone.
Then you can set the point closer to the house. Then change the battery and continue driving. And indicate a new home point further along the route.
2023-5-8
HjxQRSeH5V58
Remote control cannot be set as a home point.
2023-5-8
DuRavary
Flight distance : 125135 ft
I’m confused; it sounds as though you were ignoring the basic rules about flying a drone and were then surprised when the drone did as it does.
2023-5-22
HjxQRSeH5V58
Please don't get confused….
It's just that you only realize how wrong these rules are when you see them in the field.
New firmware releases often serve to change the rules of the drone.
2023-5-22
Mobilehomer
Flight distance : 18135846 ft
HjxQRSeH5V58 Posted at 5-8 01:48
Yes it can. Not dynamic, but it can be set as HP.
2023-5-22
HjxQRSeH5V58
When the pilot is being tracked, as in this case, only the dynamic mode is needed
2023-5-22
Sean-bumble-bee
That is incorrect but it is a static home point.
''When the pilot is being tracked, as in this case, only the dynamic mode is needed'', for you in the circumstances of this thread, you might want this option but others have different wants.
For clarity I repeat a dynamic home point would be useful to many people, is Litchi available for the Mini 3 Pro yet? From memory Litchi has a dynamic home point setting, whether or not it actuially works I do not know.
2023-5-22
HjxQRSeH5V58
Of course I was talking about dynamic home point. In fact, in my first post I said:
“But what's the point of all this? It is also not practicable to manually and continuously update the Home Point while pedaling or running. “
2023-5-22
HjxQRSeH5V58
Sean-bumble-bee Posted at 5-22 22:30
“ you might want this option but others have different wants.”
Having an additional dynamic home point option doesn't detract from what others have different wants.
2023-5-22
djiuser_SwgXPHgTqxAj
Poland
I really dont get it. The thread is not about a bug in the firmware or the app. It relates to a requirements that missed a usecase scenario. If your TV would turn off when you press mute button, or change channels when you press volume up button, even if the manual says so, it wouldnt be okay and logical even if there is a workaround. If the drone is capable od tracking and some kind of autonomous flight, it would be quite obvious that the pilot might be tracked for a longer period distance, and the original launch point is now unmanned. There is a few ways to resolve the issue, either by a dynamic Home location, which is the most obvious one, The other is to have a second option to set the behaviour upon battery low level. This is a suggestion to DJI to add missing feature.
2023-5-26
HjxQRSeH5V58
djiuser_SwgXPHgTqxAj Posted at 5-26 06:17
Kind words.
Who knows why for so many what is written in the manual is unquestionable.
2023-5-26
fansf8db0d9c
Flight distance : 31801 ft
HjxQRSeH5V58 Posted at 2022-8-3 08:17
...and it had a rotating camera! Sometimes I wish I had kept mine.
2023-10-15
Sam654
Flight distance : 132667 ft
For these cases it would be good to have a Smart RTH. Maybe if the control more than a given distance from the home point, RTH comes to the control. If the control is within the given distance of home, the home is used as normal.
2023-10-15
