Aardvark
Flight distance : 384432 ft
If it's occasional, one or two second glitches once or twice during a flight then that is not unusual, caused by interference in the live video stream being sent back to your device from the aircraft. If it's more apparent when gimbal tilting up or down then it sounds more like the device struggling to process the data. You could try a different device and see if there is any improvement.
Which firmware are you using on the RC ? If its V1.8 then you could try rolling that back to V1.6, that might help. |
