Donnie - Apple 0
Flight distance : 3636782 ft
"I tried to put the latest FW on.. WM610_FW_V01.11.01.50, it but it failed... and when I tried it again (after formatting SD card and starting over) it won't even try to load " are you trying to laod this version to the Aircraft and it fails or to the RC transmiter or to both ???
Is the 1.11 firmware above what you are trying to load to the RC transmitter ??? .. If so that file is ONLY for the Aircraft and you need 1.7.8 for the RC transmitter loaded via the GO app. If you cant load that to the Aircraft then e sure to read my tips page ( below ) , It may be as simple as not fomratting the SD card correctly , Macs are notorious for this.
Couple of possibilities I see here :
1- you are not on a compatible system on the apple device , roll it back to the previous one ( the I pad FW ) then try to connect. *** Or update to the latest go app , do that first .
2- You may have a bad HDMI module on the back of the RC If updating the new app does not solve then it may be the port . ( I assume you have tried quality cables )
3- You may have a combination of things going on here, you have the apple with the problematic firmware BUT you are also trying to update the RC transmitter to the wrong version of firmware and you are doing it wrong. Need to get to 1.7.8 for the latest FW for the RC transmitter and this can ONLY be done via the Go app. ( At one time you could use the SD card with SPECIAL files to update the RC transmitter via thumbdrive , but only to version 1.6 , then DJI made that impossible. AS the matter of fact that is how the Transmitter was updated until version 1.3 )
4- You may have a bad HDMI module on the back of the RC transmitter but I need to know the above information first .
So load the latest go app to the I Pad and go from there . If it connects then great , then you need to update the RC via the GO app and a wi fi signal to it.
Make note of the below information :
MAKE SURE THE AIRCRAFT IS ALWAYS OFF WHEN UPDATING the RC TRANSMITER AND VICE VERSA . It is critical that that the RC transmiter be off when updating the Aircraft as well and be sure to remove the SD card with the firmware update on it when the update is done . NEVER FLY OR TURN ON THE RC TRANSMITER WITH A SD CARD LOADED WITH FW ON IT, IT CAN CORRUPT THE VIDEO ENCODER MODULE AND THIS COST ABOUT 300 dollars to fix.
read my tips page , only takes a few minutes and may clear some things up.
Tips: Loading NEW firmware to RC and AC- Insp. 1 Phantom ADV & PRO
Sorry for the long rambling post , I do that sometimes.....
donnie
