Separate Mavic Air Forum
3317 35 2018-1-30
jackiedh
Flight distance : 83589314 ft
Please get the Mavic Air it's Own Forum!!!
2018-1-30
sica
Flight distance : 679 ft
Israel
I agree. There is no connection between Mavic Pro / Platinum / Alpine and Mavic Air ..... Only the name '' Mavic ''
2018-1-30
QuadKid
Flight distance : 482349 ft
Just select Mavic Air from the first page of the forum under Mavic, it's up to forum users to post it the correct category to minimize traffic.
2018-1-30
hallmark007
Flight distance : 9827923 ft
I think we will eventually see this, there are many common issues which can combine all Mavics like general photos/videos Camera , we see these are already combined on phantom and a combined approach to common faults can be a big advantage , but I think we will see some columns dedicated to MavAir.
2018-1-30
DJT_MVSP
Flight distance : 2018645 ft
Singapore
I agree that the Air should its own forum since in DJI GO, it's separated from the Mavic
2018-1-30
DJI Thor
Flight distance : 13602 ft
Jackie, if you only need to info about the Mavic Air's, you can select the relative topic, them other topics will not show on the web. Thank you. air.png
2018-1-31
Montfrooij
Flight distance : 2560453 ft
QuadKid Posted at 2018-1-30 08:52
I think that is the solution indeed.
2018-1-31
Montfrooij
DJI Thor Posted at 2018-1-31 01:03
Jackie, if you only need to info about the Mavic Air's, you can select the relative topic, them other topics will not show on the web. Thank you.[view_image]
Thanks for you tip!
2018-1-31
JensIR
Flight distance : 207631 ft
That would only be a good general solution if all treads on the Air would be categorized under that topic, but in reality that is not what is going to happen.
Just to repeat myself from another thread:
In my opinion it does not really help that much to add a "mavic Air" category to the "Topics", since it depends on how posters assign "topic". And many of the other "topics" available will apply to both the Pro and the Air. For example, under "Hardware Support" and also "Accessories" you will end up with threads about both the Pro and the Air. And these types of hardware-related threads are the ones where it would be most beneficial to separate the two types, since they have no physical similaritites at all (except for using the same camera).
2018-1-31
RocketChap
Flight distance : 902034 ft
Bump this thread - yet another few minutes wasted as I read Mavic Air stuff not applicable to my Mavic Pro.
2018-3-21
RocketChap
What I need is a way to only show stuff about Mavic Pro - I'm fed up with posts that don't indicate they are Mavic Air until you have read 90% of the way through them - total waste of my time.
2018-3-21
hallmark007
RocketChap Posted at 2018-3-21 02:30
I suppose same can be said of Mavic Pro , it’s a Mavic forum, maybe just change a few headings and members can sort from there.
2018-3-21
RocketChap
hallmark007 Posted at 2018-3-21 02:37
No I don't agree - Mavic Air users can focus on Mavic Air by the filter at the top of the page (assuming of course that Mavic Air folk apply that topic when posting) - no such filter exists  for Mavic Pro.   What was a exclusively Pro forum has been usurped by Mavic Air noobs.  Over in phantom forum for example they have separate topics for P4 (two topics) P3 (three topics) and P2.  Why cant we have the same here?  The features and hardware of the Air are sufficiently different from the Pro to warrant separate topics for Pro and Air.
2018-3-21
LoSBoL
Flight distance : 666483 ft
I'm surprised that after so many remarks there still isn't an Mavic Pro filter. It would however not help against reaching older Mavic Pro topics. It would be even better if they would also include a toggle so you can choose to exclude instead of include certain categories. That would be the easiest way to filter out certain craft type topics.
2018-3-21
hallmark007
RocketChap Posted at 2018-3-21 08:53
I agree that they should have a column for Mavic Pro, this was never an exclusive forum for Mavic Pro it was as it has always said “Mavic”, and if you were here in the beginning you would know that it first started out on the phantom 4 forum.
I agree that they should set up similar to phantom forum which works very well, but if you have been around long enough you will know that these things always take to much time to implement but get done in the end.
Mavic Air users are just as entitled to use “Mavic” forum as any other Mavic users.
2018-3-21
Wachtberger
Flight distance : 261509 ft
hallmark007 Posted at 2018-3-21 09:27
I fully agree with everything. Actually I had proposed that quite a while ago already and got positive feedback from DJI Thor: https://forum.dji.com/thread-132455-1-1.html
But apparently the follow up is lagging a bit by those who deal with the forum software.
2018-3-21
hallmark007
Wachtberger Posted at 2018-3-21 09:38
It used to be dji joe who organized this sort of thing, I haven’t heard from him in a long time, maybe he has left the forum or is busy at something else, but he was the go to person who arranged for changes to the forum.
Is dji joe out there anywhere????
2018-3-21
FlyDK
Flight distance : 1636286 ft
Denmark
After many threads about the subject and great deal of time gone, I can only think that DJI staff has closed their eyes and ears for what forum users think about it.
Personally, I've been so fed up with all the Air activity that I have cut a lot of my own activity. It has become too difficult to distinguish one from another when filtering works only one way - in Air's favor.
I have nothing negative to put on the Air model, and I would like to have one. It just does not belong in my Mavic Pro forum.
2018-3-21
hallmark007
FlyDK Posted at 2018-3-21 11:05
This was never the Mavic Pro forum. Just the Mavic Forum.
2018-3-21
Yordan
Flight distance : 903783 ft
Bulgaria
this is enough for mavic air
2018-3-21
Bob Brown
Flight distance : 4209662 ft
How do I see just Mavic Pro posts?!?!?!
2018-3-21
FlyDK
Denmark
hallmark007 Posted at 2018-3-21 11:17
I know that, but the Pro was the first and only Mavic until the Platinum - which I also consider a Mavic, unlike the Air. What will be next ... an "Ultimate" or a "Basic" - again with a different look ..? Air and any future models steal the image, confuse and create disorder.
2018-3-21
FlyDK
Denmark
Bob Brown Posted at 2018-3-21 12:13
You don't... that's the problem in a nutshell.
2018-3-21
hallmark007
FlyDK Posted at 2018-3-21 13:03
Mavic forum should be for Mavics , we will probably see Mavic2 soon and this will take over the forum from MavAir etc etc , all that needs to be done is to tidy this forum up, it was the same at phantom forum which now works well.
Hopefully moderators will forward our discussions and dji engineers will come on board soon and tidy up.
2018-3-21
RocketChap
I think we should bump this up the forum regularly - otherwise its just going to get forgotten.
2018-3-21
hallmark007
RocketChap Posted at 2018-3-21 13:29
Bump !!!!!!!!! bump bump bump...........;-)
2018-3-21
verizon28
Flight distance : 1444190 ft
I’d love to have a separate forum for the Air so I don’t have to hear about all of the horrible gimbal issues with the Pro or how a soft landing breaks it so it hangs by a rubber band.
2018-3-21
RocketChap
verizon28 Posted at 2018-3-21 13:52
Its already available to you - just select Mavic Air at the top of the Mavic forum.
2018-3-22
RocketChap
Hi DJI Thor - are there any plans to make "Mavic Pro" a Mavic topic - just like "Mavic Air" ? - if so, when is it likely to be added to the website?
2018-3-22
DJI Thor
RocketChap Posted at 2018-3-22 15:16
We had forwarded the requirement to the relative department, if they are considering doing this, maybe it will be available. But I have yet received the news. Thank you for understanding.
2018-3-23
RocketChap
DJI Thor Posted at 2018-3-23 03:18
Thanks - can I also suggest you also prepare them for separating the Mavic 2 in a similar way.
2018-3-23
RocketChap
I'd love to filter out the Mavic Air so I don't have to hear about the limited WiFi range, lack of waypoints ...
2018-3-23
DJI Thor
RocketChap Posted at 2018-3-23 09:17
Sorry for the late reply. Though I have no news about the new product, the idea will be transferred.
2018-3-28
LoSBoL
'Bump'
Why hasn't this been fixed already? It's not rocket science, how hard can it be to add a Mavic Pro filter?
2018-4-11
hallmark007
LoSBoL Posted at 2018-4-11 04:00
'Bump'
Well forum used to be looked after by dji joe, he was the guy who brought the forum along to where it is today, but he seems to be gone from this forum and I don’t know who is responsible for it now, but if changes are not made the forum could go downhill very fast.
2018-4-11
LoSBoL
hallmark007 Posted at 2018-4-11 05:08
I dropped in a line in the ongoing 'Forum community enhancement' thread, along with a PM to DJI Joe to take a look. Lets hope this gets picked up soon.
https://forum.dji.com/forum.php? ... 691&fromuid=1506194
2018-4-11
