georgebguedes
Flight distance : 1097188 ft
Brazil
Hi, guys! I have experienced some slight drifts with my Mavic Air. I have noticed in other flights before, in different locations, and while flying today I noticed again, so I uploaded the flight data to see if you guys could help me. The flight data is here and this is the strange behaviour: I am hovering the aircraft, and then the without touching any sticks the aircraft starts to slightly drift. I even pull the right stick all the way to the back and right to bring it back (as you can see on the photo attached), but it simply doesn't do anything. The aircraft continues to drift, so I change the direction of the aircraft to the right and then I gained the control back again, being able to flight foward. In the exact moment that this happened I received a high wind warning but the airdata website indicates winds of 14mph. I don't have much experience so I would to like to know your opinions on what happened, if the wind in this velocity could probably cause that or not, if everything is normal with my aircraft or maybe it's a problem of my unit.
Thank you so much for your help in advance,
George
