spookster
Flight distance : 419649 ft
absoluted44 Posted at 2018-10-9 00:03
I do have a question but not about your setup, I can't start a new thread so I guess I'll post it here. So, I want to get Osmo 2 for my S9+, but I want to put on Moment case and lenses, I've heard you can add counterweight to Osmo 2, but will it be able to support all the weight and will the Osmo 2 be able to hold S9+ with Moment case on it. Also is there a adapter of some sort, so I can use the Osmo 2 with GoPro Hero 7 Black? Thanks in advance.
With the sort of holding plate I use, you could use your go pro with the osmo mobile 2.
In wide view you will have part of the gimbal in the picture.
The moment case will probably not fit in the osmo because it is to thick, according to this thead https://forum.dji.com/thread-139075-1-1.html even the s9+ alone is too big and heavy for the osmo mobile 2. |
