RTH without GPS
4274 19 2019-2-1
mertsendag
Flight distance : 88770 ft
Turkey
Hi folks,
I was wondering what would happen in the following case:
• Spark has GPS lock and records home point successfully before takeoff
• While in the air, it loses quality GPS signal and enters OPTI mode (which actually does happen)
Will it still be able to return to home point?
If not, doesn't this make flying dangerous as in case of GPS signal loss, we are going down? In that case, RTH is good only in cases of RC connection loss?
Regards
2019-2-1
Bsr387
Flight distance : 7221 ft
Turkey
Hello there, sparky can't go homepoint coordinates without seeing "current position" via the GPS. Actually ı guess no drone could do that. And yes it is always dangerous to fly in ATTI mode cause fly aways most of the time.
2019-2-1
Wolferl
Flight distance : 23793 ft
Austria
Hi,
How should the drone come back to a home point, if it doesn't even know where it is heading after an IMU failure?
In almost all the cases with the Spark flyaways it is technically not a loss of GPS reception, but an IMU problem, which results in all sorts of error messages like compass errors, GPS signal losses, yaw errors and so on. DJI should really correct this annoying problem.
If you want to do some ATTI mode training yourself and see how Sparky behaves then, see this thread.
Cheers,
Wolferl
2019-2-1
mertsendag
Turkey
Wolferl Posted at 2-1 04:45
Hi,
Does this mean that if I lose RC connection somehow, and the aircraft loses GPS signal, there is no way for it to come back?
2019-2-1
spookster
Flight distance : 419649 ft
that is correct.
2019-2-1
Wolferl
Austria
mertsendag Posted at 2-1 05:13
Exactly.
If you lose GPS reception/fix -> you're screwed.
If you get compass errors -> you're screwed.
If you get yaw errors -> you're screwed.
If any of that happens, you'll need to pilot your Spark home in ATTI mode. That's why I think everybody should be able to that.
Cheers,
Wolferl
2019-2-1
darkfull1
Flight distance : 13114 ft
Switzerland
no It can't go back to home point if it doesn't know where it is. If you doesn't have gps the drone doesn't know where it is.
2019-2-1
eYeSkYeYe
Croatia
On it's own, no way....
Reasonable skilled pilot should be able to bring it back with ease.
2019-2-1
Lysak2003
Flight distance : 500052 ft
Ukraine
That's why you should keep your drone within your line of sight.
2019-2-1
mertsendag
Turkey
eYeSkYeYe Posted at 2-1 06:50
How so? If aircraft disconnects (no RC) and loses GPS it is technically impossible to move it in any direction
2019-2-1
mertsendag
Turkey
Lysak2003 Posted at 2-1 06:56
Again, if aircraft disconnects (no RC) and loses GPS it will be impossible to move it in any direction even if you see it
2019-2-1
eYeSkYeYe
Croatia
mertsendag Posted at 2-1 07:26
Yep, you have the point....
In my experience, full connection loss is very rare though.... And even so, you are usually able to restore it pretty quickly. Than usually video link restores and it's just GPS that takes ages to get proper fix.
2019-2-1
Lysak2003
Ukraine
it will be a sad situation
2019-2-1
StetsonWatkins
Flight distance : 1871611 ft
Good tips to consider when flying with a bad GPS signal. This has happened to me multiple times.
2019-2-1
JJB*
Flight distance : 12401030 ft
darkfull1 Posted at 2-1 06:36
hi,
Not completely right. Most of the time GPS signals are OK but not used by the drone due to some other erorrs! (yaw, imu, speed calculation)
So the attitude indicator and compass does indicate the drone heading, so in ATTI you can use this to find your way manual back home.
Only with a 'good' compass error it is not possible to fly back (if out of sight) cause the GO 4 app screen will not give the correct information.
See this flight ; yaw errors so into ATTI mode, but GPS signals are OK (LAT LON data available).
cheers
JJB
2019-2-1
JJB*
nope, see #15
2019-2-1
Warriewoodlad
Flight distance : 625230 ft
If you can't see your Spark, this would be correct. Even if you can see it, some training may be necessary before you can successfully guide it home.
2019-2-1
Sayhelloforme
Flight distance : 8133219 ft
If the RC loses connection by the spark flying out of range, or if the RC battery dies or even if you point the  antennas down to the ground by mistake the  Spark will RTH as long as it does NOT lose GPS. Maybe you knew this but just wanted to be sure.
2019-2-1
darkfull1
Switzerland
JJB* Posted at 2-1 12:27
hi,
Would be good if the drone could use these data. Fortunately (or not)  in my country you are required by law to always keep your drone in the line of sight shouldn't be a problem if I loose gps. Plus I'm kind of use to ATTI mode since I fly racing drones that don't have gps.
2019-2-3
jowlpost2
Aircraft have flight recorders, and you can store a lot in a 120 gig sD card so I bet the major OEMS are already working on it.   The big problem in the countryside is chop shops using jammers.  If you lose contact with your drone in the same location you should repot it to the police.
1-30 10:37
