Blade Strike in P mode
1599 20 2020-4-8
fans1cafe718
Flight distance : 230 ft
Blade Strike in P mode...should I worry...?
2020-4-8
m80116
Flight distance : 3264131 ft
Yes. Wondering if some front arms are softer than others or if temperature and RH play a role or else (the arms squoosh filling absorbs water).
Some reported that motor caps help in spacing the props further up and away from the body.
2020-4-8
120ccpm
Flight distance : 1396755 ft
How old are those props (how many flights/miles on them) and how do you store your MM? I would change props right away as a precaution, and see if the issue persists...
2020-4-8
DJI Natalia
Hi there, please refer to 120ccpm's reply, you are recommended to change props to see if the issue persists or not. If there is any further issue, please feel free to let us know.
2020-4-9
Dr0ne_n00b
Flight distance : 8060348 ft
Front arms flexing cause the prop to strike the body. Motor caps are one way but potentially risk overheating motors due to lack of ventilation. Other approach is 3D print and retrofit stiffeners in the front arms so they arent so flimsy.
https://dronedj.com/2020/03/24/d ... pops-hit-done-body/
https://www.thingiverse.com/thing:4102555
Would also replace the props anyway since they're damaged after striking the drone.
2020-4-9
hallmark007
Flight distance : 9827923 ft
Well I wouldn’t worry, but I would change them, props are cheap and much needed to hold craft in the air.
2020-4-9
fans1cafe718
120ccpm Posted at 4-8 12:15
hi, about 8 flights only...always in calm weather and never Sport mode.
2020-4-9
Ice_2k
Flight distance : 1132575 ft
Romania
Dr0ne_n00b Posted at 4-9 01:58
https://dronedj.com/2020/03/24/dji-mavic-mini-design-flaw-pops-hit-done-body/
I've heard this before but it doesn't seem plausible to me. What makes you think it's the arms flexing and not the props?
Judging by the video posted here, it looks like unbalanced props causing horrible vibrations and massive prop flexing: https://forum.dji.com/thread-211249-1-1.html
2020-4-9
Guorium
Flight distance : 513061 ft
fans1cafe718 Posted at 4-9 02:35
There was a theory about good props going bad somehow causing the strike in my report which was very early on this issue. But some reported relatively new units having the issue. So the conclusion was a batch of props was bad. I solved my problem by replacing the front right twice, then the front left once.
2020-4-9
DaMa
Flight distance : 889662 ft
I did it ... glued plastic parts in. Can't find anything negative. Incidentally, I am quite pain-free in matters of guarantee ... For everyone in pain, please don't do it unless DJI recommends it ...
2020-4-9
fans1cafe718
Guorium Posted at 4-9 03:48
...replaced just one prop or in pairs per arm?
...btw, my mini is dated Dec15th...
2020-4-9
fans1cafe718
DaMa Posted at 4-9 04:00
...did that fix your problem?
...maybe smear a little sharpie on fuselage and check if it get scratched...?
2020-4-9
fans1cafe718
hallmark007 Posted at 4-9 02:00
...like your humour...lol, much needed huh? lolll
2020-4-9
Guorium
fans1cafe718 Posted at 4-9 05:48
Always replace a pair as they come out of the paired molds and should be balanced.
2020-4-9
fans1cafe718
Guorium Posted at 4-9 06:12
yes...I shall.
...Just did a check in idle...props track very straight....hmmm, probably they go soft in flight...would carbon fiber blades be better and would it void the warranty...?
2020-4-9
DaMa
fans1cafe718 Posted at 4-9 05:50
I don't know, time will tell. The twisted arms were already a "nogo" for me after unpacking (10.30.2019 ordered).
The foam inserts are probably wanted by DJI. Doesn't make sense to me, the arms look like torsion springs - if they were at least damped ... maybe they wanted to take some power out of the attachment to the housing, maybe the thin housing can't take the force now? As long as he flies like this, I'm happy. If not, it was probably a "Griff ins Klo" (hand in the toilet sais the German).I also don't like the somewhat sloppy game between propeller and screw...
2020-4-9
Guorium
fans1cafe718 Posted at 4-9 07:16
yes...I shall.
No idea man. I suppose more rigid carbon would make it less prone to vibration and warping out of shape. Definitely against warranty if you fly with third party parts not approved by DJI.
2020-4-9
fans1cafe718
Guorium Posted at 4-9 15:29
If it's a blade rigidity problem, carbon fiber blades should certainly fix this without the added weight and heat issues related to engine covers.
Any of these solutions would void warranty anyways...
2020-4-10
Dr0ne_n00b
Ice_2k Posted at 4-9 03:15
Front arms are a very thin plastic and flex very easily, presumably losing rigidity over time. They are also supported by nothing but a piece of foam, unlike back arms which are a more solid plastic. The "mod" simply gives the front arms more support to be like the back arms.
2020-4-10
djiuser_GqWOvdwtD6Bz
Flight distance : 3799 ft
fans1cafe718 Posted at 2020-4-10 02:40
The only issue with using carbon fiber props is that nobody thats trustworthy really makes aftermarket props for the mavic mini, so unless you want to take your chances with amazon no name props idk what else to do .. mine isnt hitting the body and i even occassionally do a small vit of freestyle with my mini, haha i cant gelp it i fly 5 inch quads all the time so its second nature.. but back to the mini i have been trying to find a reputable company to buy carbon props from just because i wanted to do some testing. No luck.. and a buddy tried the amazon route and he had 3 put of the 8 explode when he went to take off... and he said when he opened the package they werw really rough feeling, the edges were not cleaned up at all and the top and bottom were like sandpaper so id stay clear of them unless you find a reputable manufacturer..  for 12 bucks for a complete set i just buy like 4 sets at a time so i can periodically change them out.. they are pretty tough
2021-5-5
Guorium
djiuser_GqWOvdwtD6Bz Posted at 5-5 20:52
Carbon prop would probably damage the fuselage more. DJI reinforced front arm for mini 2 and the issue is no more. So flexibly arm is likely the main issue here.
2021-5-6
