RC Antenna split into two
1120 8 2015-11-13
juanpaulofloren
Philippines
Hi Guys,
I need your help. Where can i buy a replacement antenna for my transmitter?
It snapped into two when I accidentally dropped the transmitter. The transmitter is working fine its just the antenna that needs replacement.
I cannot afford to buy an entire new transmitter and besides mine is working fine.
I tried searching for spares but to no availability.
Was also wondering if i can replace it with some router antennas that are available on the market for 2.4ghz?
Your inputs are much appreciated..
2015-11-13
Kneepuck
Flight distance : 275105 ft
You didn't say which controller or which P3 you had.  So it depends.  The P3 advanced and pro use 2.4ghz control.  The P3S uses 5.8ghz control signal.  In either case,  yes you can do a mod to install a connector and use an external screw on type antenna.
2015-11-13
juanpaulofloren
Philippines
I have a P3A.
2015-11-14
AK Eagle
If it was me I would get one of the long range antenna setups like the one made by DBS. Even if you will never go out that far at least you will have excellent reception.
2015-11-14
Cetaman
Flight distance : 2528264 ft
Aloha juan,
     Sorry to hear about your antennae problem.  Hope you are able to get a replacement.  I will keep my eyes open and let you know if I learn something.
     I am curious about the unusual shape of the antennae and what is inside.  As you noted, you cannot just go out and buy a P3 antennae.  Can you describe or post a photo of what is inside the antennae?  I have tried to see which antennae has the P3 flight control and which antennae handles the downlink.  But, my results seem to indicate that both antenna have both transmitter and downlink inside.  That would explain why the antennae is shaped that way.
     Good luck with your antennae!  I will keep looking.
Aloha and Drone On!
2015-11-19
Rocket_Aus
Flight distance : 1526929 ft
http://dbsmods.com/
2015-11-20
juanpaulofloren
Malaysia
Cetaman Posted at 2015-11-20 10:37
Aloha juan,
     Sorry to hear about your antennae problem.  Hope you are able to get a replaceme ...
If its the antenna's contents you want to see (check this thread [url= http://forum.dji.com/thread-16082-1-1.html] http://forum.dji.com/thread-16082-1-1.html[/url]
I did some research and someone has already done a mod such as this see the thread below http://forum.dji.com/thread-31284-1-1.html
I ordered some connectors and hopefully will be able to mimc what he has done.
2015-11-25
DJI-Tim
DJI Team
you also could upgrade your antenna to the more powerful one. but it might take some time and money
2015-11-25
Cetaman
juanpaulofloren Posted at 2015-11-25 08:55
If its the antenna's contents you want to see (check this thread http://forum.dji.com/thread-16082 ...
Aloha juan,
     Mahalo for the links.  Now it makes sense.
Aloha and Drone On!
2015-11-25
