Geebax
Yes, there is definitely some movement in that footage, but it only seems to be horizontally. You might check that the foam block has been removed, and also put it in a hover just in front of you and look to see if you can see any movement of the camera.
It does not seem to be a problem when the aircraft is on the ground, only in the air. Next try swapping the props for the spare set. |
