inspire update!!
2735 35 2016-3-20
patrickdiddly
Sick as a chip today...managed to update inspire 1 after help from a nephew but controller wont connect to inspire anymore after updating????
tried alsorts, usb micro sd direct from inspire camera please help i am slowely going mad!!!
Pat.
2016-3-20
DJI-Tim
Hello Pat!  did you try re-linking your RC?
2016-3-20
patrickdiddly
DJI-Tim Posted at 2016-3-21 15:31
Hello Pat!  did you try re-linking your RC? https://www.youtube.com/watch?v=kkynWM0Wh2U
Thanks Tim but I tried that last night, when I click on linking on the dji go app it says check frequency?? or something also it does not give me a choice to pick master? has the update on the controller failed? I tried to redo that last night also and it does not give me the need to upgrade option? I am at a loss
Please help
Pat.
2016-3-21
DJI-Tim
Could you please post the update log here, so we can take a look at it. Thank you!
2016-3-21
I1ADDICT
patrickdiddly@a Posted at 2016-3-21 02:12
Thanks Tim but I tried that last night, when I click on linking on the dji go app it says check fr ...
Roll back to the previous update?  DJI lets  you go back 2 previous versions I believe, and then try to go forward from there if that works for you.  It's worked for me in the past on other platforms.Good luck.
2016-3-21
patrickdiddly
I1ADDICT Posted at 2016-3-21 18:37
Roll back to the previous update?  DJI lets  you go back 2 previous versions I believe, and then tr ...
Don't know how to do that could you advise, thankyou for your time
Pat.
2016-3-21
patrickdiddly
DJI-Tim Posted at 2016-3-21 17:43
how do I retrieve this log file??
2016-3-21
Donnie
Flight distance : 3636782 ft
   Make sure you have updated the Transmitter as well,  have you already done this? You cant have the Aircraft Updated with out the Transmitter being updated.  Check this first.
-donnie
2016-3-21
patrickdiddly
Donnie Posted at 2016-3-21 21:22
Make sure you have updated the Transmitter as well,  have you already done this? You cant have th ...
Yes have done it all
2016-3-21
Donnie
Can you take a screenshot of your firmware please: Or just confirm if it looks EXACTLY like this or just note the diffferences, be sure to tun Aircraft on and of course go app and RC.
-thanks- donnie............  soryy for all the questions but need them to help solve issues
2016-3-21
Donnie
patrickdiddly@a Posted at 2016-3-21 07:18
Pat.
The  log is on the SD card you used to update the aircraft, here is a link on how to view it:
http://forum.dji.com/thread-44546-1-1.html
2016-3-21
Donnie
Pat.
     Also I would not "Rollback just yet"  just so you know you rollback the same way You updated.  you just place the  Firmware  on the SD card from your previous  FW version.  If you loaded 1.7 with success and you were previously at 1.6... You would simply load 1.6 on the SD card and reload.  Dont do that just yet until we confirm what FW you have loaded on everything first.  Therfore  we need the info on the "About " page of the Go APP.
What was the Last  successful FW you had loaded by the way? before attempting 1.7   Was it 1.6 or something lower ?  Did you skip any ?
I need to go to work , but I will get back to you when I can,  also other members will be able to follow the flow of Info and offer suggestions as well
-donnie
2016-3-21
patrickdiddly
Donnie Posted at 2016-3-21 13:45
Can you take a screenshot of your firmware please: Or just confirm if it looks EXACTLY like this or ...
This is my problem...my controller wont connect to the craft so i cannot see that info? also i have tried to reset my controller using the four button method and it wont reset?
Helllllpppppppp!!!
Pat.
2016-3-21
patrickdiddly
Donnie Posted at 2016-3-21 14:02
Also I would not "Rollback just yet"  just so you know you rollback the same way You updated.  ...
Just the one before i have not skipped any?
2016-3-21
patrickdiddly
patrickdiddly@a Posted at 2016-3-21 17:32
I have just tried to roll back both controllers and none of them will down grade or upgrade just behaving like white shiny bricks??
2016-3-21
patrickdiddly
on the about page it says NA and NA for inspire and controller
2016-3-21
patrickdiddly
Donnie Posted at 2016-3-21 19:09
I am screwd right now myself so as soon as I can I will try and Help, this whole update (Latest )  ...
Yep just downgraded the inspire and one controller came on asking to update, i did on the app it failed,
upgraded inspire again and no controllers work ARGHHHHHHHHHHH!!!!!!!
Thanks Dji for turning my aircraft into a brick!
2016-3-21
patrickdiddly
patrickdiddly@a Posted at 2016-3-21 19:20
Yep just downgraded the inspire and one controller came on asking to update, i did on the app it fa ...
for the record one controller is showing 1.6.00.40 remote 1.5.80
other one showing 1.6.00 remote 1.5
2016-3-21
Donnie
patrickdiddly@a Posted at 2016-3-21 14:25
other one showing 1.6.00 remote 1 ...
The App  2.71
The RC should be 1.5.80
The Aircraft 1.6.00.40
Camera   1.7.00.90
I think you just have to get it to link.  Let me see if I can find how to do manual link , Have you tried this yet?  Not through the RC Link?
2016-3-21
patrickdiddly
Donnie Posted at 2016-3-21 19:32
The App  2.71
yes tried the holding red button on craft, but cant get link function to work on any controller?
2016-3-21
Donnie
patrickdiddly@a Posted at 2016-3-21 14:20
Patrick,  I helped a gent the other day with similar problem.  Here is what you do go to this link and down at the end  the Poster is very happy because he downloaded this file to his remote with a thumb drive that he loaded with this file  c1 fw v 01.05.0080.  The file is on the page I am goiing to link for you.  simply download the file to a thumb drive and install on your transmitter.  It fixed his, it should help yours.
try it.  Read it and  download the file LINK from post #10 and download this bin file to your transmitter only.
http://forum.dji.com/thread-46041-1-1.html
2016-3-21
patrickdiddly
Donnie Posted at 2016-3-21 20:22
Patrick,  I helped a gent the other day with similar problem.  Here is what you do go to this link  ...
[00004441][01 00] Firmware upgrade finished successfully.
[00004564]Done.
[00004602]Packet [C:\WM610_FW_V01.03.00.00.bin] resumed, card sn [0xda9eb36a].
[00004645]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004715]Version checking[2]...
[00004758][01 00][05] v1.19.3422 -> v1.19.3422
[00004790][01 01][00] v1.8.2729 -> v1.19.3422 need upgrade
[00004855][03 05][00] v34.1.0.5 -> v34.1.0.5
[00004918][03 06][00] v2.0.5.14 -> v2.2.6.33 need upgrade.
[00004964][04 00][00] v1.16.0.76 -> v1.26.0.3 need upgrade.
[00005015][05 00][00] v2.5.6.1 -> v3.0.6.1 need upgrade.
[00005072][08 00][00] v1.12.0.21 -> v1.14.0.25 need upgrade.
[00005120][09 00][00] v1.7.0.3 -> v1.8.0.0 need upgrade.
[00005176][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00005277][12 00][00] v1.3.0.60 -> v1.8.0.0 need upgrade.
[00005375][12 01][00] v1.3.0.60 -> v1.8.0.0 need upgrade.
[00005456][12 02][00] v1.3.0.60 -> v1.8.0.0 need upgrade.
[00005563][12 03][00] v1.3.0.60 -> v1.8.0.0 need upgrade.
[00005666][15 00][00] v1.1.2.0 -> v1.1.2.0
[00005735][17 00][00] v1.1.0.1 -> v1.1.0.4 need upgrade.
[00005838][17 01][00] v2.0.0.1 -> v2.0.0.8 need upgrade.
[00005905][19 00][00] v1.0.8.96 -> v1.0.8.96
[00005975]Done.
[00006027]Firmware upgrading[2]...
[00006221][01 01] Firmware upgrade start...
[00036704][01 01] Firmware upgrade finished successfully.
[00037597][08 00] Firmware upgrade start...
[00370965][08 00] Firmware upgrade finished successfully.
[00371019][12 00] Firmware upgrade start...
[00426337][12 00] Firmware upgrade finished successfully.
[00426398][12 01] Firmware upgrade start...
[00481891][12 01] Firmware upgrade finished successfully.
[00481945][12 02] Firmware upgrade start...
[00538026][12 02] Firmware upgrade finished successfully.
[00538131][12 03] Firmware upgrade start...
[00593761][12 03] Firmware upgrade finished successfully.
[00594002][03 06] Firmware upgrade start...
[00007299]========== 2015.08.11 11:20:34. boot(15) ============
[00007434]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0xda9eb36a].
[00007582]Packet upgrade start...
[00007626]Packet checking...
[00007667]Packet vlink 01.03.0000 <-> 01.02.0000.
[00007736]Done.
[00007774]Version checking[1]...
[00007830][01 00][00] v1.19.3422 -> v1.19.3422
[00007874][01 01][00] v1.19.3422 -> v1.19.3422
[00007955][03 05][00] v34.1.0.5 -> v34.1.0.5
[00008035][03 06][00] v1.0.0.1 -> v2.2.6.33 need upgrade.
[00008094][04 00][00] v1.16.0.76 -> v1.26.0.3 need upgrade.
[00008175][05 00][00] v2.5.6.1 -> v3.0.6.1 need upgrade.
[00008223][08 00][00] v1.14.0.25 -> v1.14.0.25
[00008294][09 00][00] v1.7.0.3 -> v1.8.0.0 need upgrade.
[00008415][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00020965][12 00][00] device not detected.
[00033504][12 01][00] device not detected.
[00046043][12 02][00] device not detected.
[00058582][12 03][00] device not detected.
[00058688][15 00][00] v1.1.2.0 -> v1.1.2.0
[00058751][17 00][00] v1.1.0.1 -> v1.1.0.4 need upgrade.
[00058858][17 01][00] v2.0.0.1 -> v2.0.0.8 need upgrade.
[00058905][19 00][00] v1.0.8.96 -> v1.0.8.96
[00058945]Done.
[00060983]Waiting for user confirm...
[00004692]========== remo-con disconnect. boot(15) ============
[00004730]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0xda9eb36a].
[00004773]Packet upgrade start...
[00004820]Packet checking...
[00004865]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004932]Done.
[00004969]Version checking[1]...
[00005013][01 00][00] v1.19.3422 -> v1.19.3422
[00005053][01 01][00] v1.19.3422 -> v1.19.3422
[00005130][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005190][03 06][00] v1.0.0.1 -> v2.2.6.33 need upgrade.
[00005240][04 00][00] v1.16.0.76 -> v1.26.0.3 need upgrade.
[00005310][05 00][00] v2.5.6.1 -> v3.0.6.1 need upgrade.
[00005380][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005440][09 00][00] v1.7.0.3 -> v1.8.0.0 need upgrade.
[00005530][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00018088][12 00][00] device not detected.
[00030627][12 01][00] device not detected.
[00043248][12 02][00] device not detected.
[00055787][12 03][00] device not detected.
[00055883][15 00][00] v1.1.2.0 -> v1.1.2.0
[00055966][17 00][00] v1.1.0.1 -> v1.1.0.4 need upgrade.
[00056066][17 01][00] v2.0.0.1 -> v2.0.0.8 need upgrade.
[00056110][19 00][00] v1.0.8.96 -> v1.0.8.96
[00056149]Done.
[00058186]Waiting for user confirm...
[00005113]========== 2015.08.13 09:04:47. boot(15) ============
[00005150]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0xda9eb36a].
[00005192]Packet upgrade start...
[00005237]Packet checking...
[00005278]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005353]Done.
[00005404]Version checking[1]...
[00005479][01 00][00] v1.19.3422 -> v1.19.3422
[00005531][01 01][00] v1.19.3422 -> v1.19.3422
[00005614][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005715][03 06][00] v1.0.0.1 -> v2.2.6.33 need upgrade.
[00005776][04 00][00] v1.16.0.76 -> v1.26.0.3 need upgrade.
[00005854][05 00][00] v2.5.6.1 -> v3.0.6.1 need upgrade.
[00005913][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005980][09 00][00] v1.7.0.3 -> v1.8.0.0 need upgrade.
[00006035][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00018587][12 00][00] device not detected.
[00031139][12 01][00] device not detected.
[00009316]========== 2015.08.13 09:05:44. boot(15) ============
[00009357]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0xda9eb36a].
[00009409]Packet upgrade start...
[00009462]Packet checking...
[00009506]Packet vlink 01.03.0000 <-> 01.02.0000.
[00009588]Done.
[00009625]Version checking[1]...
[00009663][01 00][00] v1.19.3422 -> v1.19.3422
[00009699][01 01][00] v1.19.3422 -> v1.19.3422
[00009778][03 05][00] v34.1.0.5 -> v34.1.0.5
[00009857][03 06][00] v1.0.0.1 -> v2.2.6.33 need upgrade.
[00009903][04 00][00] v1.16.0.76 -> v1.26.0.3 need upgrade.
[00009978][05 00][00] v2.5.6.1 -> v3.0.6.1 need upgrade.
[00010032][08 00][00] v1.14.0.25 -> v1.14.0.25
[00010082][09 00][00] v1.7.0.3 -> v1.8.0.0 need upgrade.
[00010237][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00005129]========== remo-con disconnect. boot(15) ============
[00005169]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0xda9eb36a].
[00005209]Packet upgrade start...
[00005256]Packet checking...
[00005299]Packet vlink 01.03.0000 <-> 01.02.0000.
[00005377]Done.
[00005436]Version checking[1]...
[00005489][01 00][00] v1.19.3422 -> v1.19.3422
[00005552][01 01][00] v1.19.3422 -> v1.19.3422
[00005643][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005743][03 06][00] v1.0.0.1 -> v2.2.6.33 need upgrade.
[00005792][04 00][00] v1.16.0.76 -> v1.26.0.3 need upgrade.
[00005863][05 00][00] v2.5.6.1 -> v3.0.6.1 need upgrade.
[00005941][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005988][09 00][00] v1.7.0.3 -> v1.8.0.0 need upgrade.
[00006062][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00018627][12 00][00] device not detected.
[00031172][12 01][00] device not detected.
[00043711][12 02][00] device not detected.
[00056254][12 03][00] device not detected.
[00056355][15 00][00] v1.1.2.0 -> v1.1.2.0
[00056418][17 00][00] v1.1.0.1 -> v1.1.0.4 need upgrade.
[00056517][17 01][00] v2.0.0.1 -> v2.0.0.8 need upgrade.
[00056567][19 00][00] v1.0.8.96 -> v1.0.8.96
[00056603]Done.
[00058648]Waiting for user confirm...
[00068685]Timeout, start upgrade automatically.
[00068764]Firmware upgrading[1]...
[00069010][03 06] Firmware upgrade start...
[00298574][03 06] Firmware upgrade finished successfully.
[00298656][17 00] Firmware upgrade start...
[00359792][17 00] Firmware upgrade finished successfully.
[00359844][17 01] Firmware upgrade start...
[00413472][17 01] Firmware upgrade finished successfully.
[00413540][11 00] Firmware upgrade start...
[00494616][11 00] Firmware upgrade finished successfully.
[00494678][05 00] Firmware upgrade start...
[00539033][05 00] Firmware upgrade finished successfully.
[00539097][09 00] Firmware upgrade start...
[00590689][09 00] Firmware upgrade finished successfully.
[00590856][04 00] Firmware upgrade start...
[00654799][04 00] Firmware upgrade finished successfully.
[00654840]Done.
[00654879]Version checking[2]...
[00654918][01 00][00] v1.19.3422 -> v1.19.3422
[00654958][01 01][00] v1.19.3422 -> v1.19.3422
[00655039][03 05][00] v34.1.0.5 -> v34.1.0.5
[00655120][03 06][05] v2.2.6.33 -> v2.2.6.33
[00655164][04 00][05] v1.26.0.3 -> v1.26.0.3
[00655219][05 00][05] v3.0.6.1 -> v3.0.6.1
[00655271][08 00][00] v1.14.0.25 -> v1.14.0.25
[00655324][09 00][05] v1.8.0.0 -> v1.8.0.0
[00655379][11 00][05] v3.7.15.9 -> v3.7.15.9
[00655479][12 00][00] v1.8.0.0 -> v1.8.0.0
[00655579][12 01][00] v1.8.0.0 -> v1.8.0.0
[00655678][12 02][00] v1.8.0.0 -> v1.8.0.0
[00655799][12 03][00] v1.8.0.0 -> v1.8.0.0
[00655896][15 00][00] v1.1.2.0 -> v1.1.2.0
[00655979][17 00][05] v1.1.0.4 -> v1.1.0.4
[00656079][17 01][05] v2.0.0.8 -> v2.0.0.8
[00656130][19 00][00] v1.0.8.96 -> v1.0.8.96
[00656168]Packet upgrade finish successfully.
[00004724]========== remo-con disconnect. boot(15) ============
[00004764]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0xda9eb36a].
[00004803]Packet upgrade start...
[00004858]Packet checking...
[00004901]Packet vlink 01.03.0000 <-> 01.02.0000.
[00004939]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00004985]Done.
[00005028]Version checking[1]...
[00005065][01 00][00] v1.19.3422 -> v1.19.3422
[00005111][01 01][00] v1.19.3422 -> v1.19.3422
[00005184][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005284][03 06][00] v2.2.6.33 -> v2.2.6.33
[00005360][04 00][00] v1.26.0.3 -> v1.26.0.3
[00005444][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005504][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005584][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005664][11 00][00] v3.7.1.0 -> v3.7.15.9 need upgrade.
[00005764][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005864][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005964][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006064][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006176][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006423][17 00][00] v1.1.0.4 -> v1.1.0.4
[00006544][17 01][00] v2.0.0.8 -> v2.0.0.8
[00006598][19 00][00] v1.0.8.96 -> v1.0.8.96
[00006646]Done.
[00008685]Waiting for user confirm...
[00018761]Timeout, start upgrade automatically.
[00018851]Firmware upgrading[1]...
[00018912][11 00] Firmware upgrade start...
[00099994][11 00] Firmware upgrade finished successfully.
[00100037]Done.
[00100078]Version checking[2]...
[00100120][01 00][00] v1.19.3422 -> v1.19.3422
[00100165][01 01][00] v1.19.3422 -> v1.19.3422
[00100255][03 05][00] v34.1.0.5 -> v34.1.0.5
[00100342][03 06][00] v2.2.6.33 -> v2.2.6.33
[00100388][04 00][00] v1.26.0.3 -> v1.26.0.3
[00100455][05 00][00] v3.0.6.1 -> v3.0.6.1
[00100503][08 00][00] v1.14.0.25 -> v1.14.0.25
[00100561][09 00][00] v1.8.0.0 -> v1.8.0.0
[00100636][11 00][05] v3.7.15.9 -> v3.7.15.9
[00100735][12 00][00] v1.8.0.0 -> v1.8.0.0
[00100835][12 01][00] v1.8.0.0 -> v1.8.0.0
[00100915][12 02][00] v1.8.0.0 -> v1.8.0.0
[00101015][12 03][00] v1.8.0.0 -> v1.8.0.0
[00101118][15 00][00] v1.1.2.0 -> v1.1.2.0
[00101175][17 00][00] v1.1.0.4 -> v1.1.0.4
[00101275][17 01][00] v2.0.0.8 -> v2.0.0.8
[00101324][19 00][00] v1.0.8.96 -> v1.0.8.96
[00101364]Packet upgrade finish successfully.
[00006699]========== 2015.09.24 17:05:36. boot(15) ============
[00006743]Packet [C:\WM610_FW_V01.04.00.10.bin] detected, card sn [0xbb4b2ace].
[00006793]Packet upgrade start...
[00006843]Packet checking...
[00006896]Packet vlink 01.04.0010 <-> 01.03.0000.
[00006936]Record vlink 01.03.0000 <-> 01.02.0000 (flow = 0).
[00006983]Done.
[00007032]Version checking[1]...
[00007070][01 00][00] v1.19.3422 -> v1.19.3422
[00007110][01 01][00] v1.19.3422 -> v1.19.3422
[00007198][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007278][03 06][00] v2.2.6.33 -> v2.3.0.13 need upgrade.
[00007339][04 00][00] v1.26.0.3 -> v1.26.0.21 need upgrade.
[00007418][05 00][00] v3.0.6.1 -> v3.0.6.1
[00007474][08 00][00] v1.14.0.25 -> v1.14.0.25
[00007653][09 00][00] v1.8.0.0 -> v1.8.0.0
[00007742][11 00][00] v3.7.15.9 -> v3.7.15.10 need upgrade.
[00007858][12 00][00] v1.8.0.0 -> v1.8.0.0
[00007958][12 01][00] v1.8.0.0 -> v1.8.0.0
[00008058][12 02][00] v1.8.0.0 -> v1.8.0.0
[00008178][12 03][00] v1.8.0.0 -> v1.8.0.0
[00008337][15 00][00] v1.1.2.0 -> v1.1.2.0
[00008426][17 00][00] v1.1.0.4 -> v1.1.0.4
[00008558][17 01][00] v2.0.0.8 -> v2.0.0.8
[00008623][19 00][00] v1.0.8.96 -> v1.0.8.96
[00008674]Done.
[00010725]Waiting for user confirm...
[00020769]Timeout, start upgrade automatically.
[00020851]Firmware upgrading[1]...
[00021104][03 06] Firmware upgrade start...
[00260793][03 06] Firmware upgrade finished successfully.
[00260847][11 00] Firmware upgrade start...
[00342626][11 00] Firmware upgrade finished successfully.
[00342719][04 00] Firmware upgrade start...
[00413590][04 00] Firmware upgrade finished successfully.
[00413804]Done.
[00413904]Version checking[2]...
[00413943][01 00][00] v1.19.3422 -> v1.19.3422
[00413983][01 01][00] v1.19.3422 -> v1.19.3422
[00414060][03 05][00] v34.1.0.5 -> v34.1.0.5
[00414140][03 06][05] v2.3.0.13 -> v2.3.0.13
[00414185][04 00][05] v1.26.0.21 -> v1.26.0.21
[00414260][05 00][00] v3.0.6.1 -> v3.0.6.1
[00414318][08 00][00] v1.14.0.25 -> v1.14.0.25
[00414371][09 00][00] v1.8.0.0 -> v1.8.0.0
[00414441][11 00][05] v3.7.15.10 -> v3.7.15.10
[00414540][12 00][00] v1.8.0.0 -> v1.8.0.0
[00414640][12 01][00] v1.8.0.0 -> v1.8.0.0
[00414740][12 02][00] v1.8.0.0 -> v1.8.0.0
[00414840][12 03][00] v1.8.0.0 -> v1.8.0.0
[00414947][15 00][00] v1.1.2.0 -> v1.1.2.0
[00415020][17 00][00] v1.1.0.4 -> v1.1.0.4
[00415119][17 01][00] v2.0.0.8 -> v2.0.0.8
[00415171][19 00][00] v1.0.8.96 -> v1.0.8.96
[00415212]Packet upgrade finish successfully.
[00006621]========== 2015.09.24 17:26:25. boot(15) ============
[00006668]Packet [C:\WM610_FW_V01.04.00.10.bin] detected, card sn [0xbb4b2ace].
[00006720]Packet upgrade start...
[00006770]Packet checking...
[00006916]Packet vlink 01.04.0010 <-> 01.03.0000.
[00006968]Record vlink 01.04.0010 <-> 01.03.0000 (flow = 0).
[00007012]Done.
[00007059]Version checking[1]...
[00007112][01 00][00] v1.19.3422 -> v1.19.3422
[00007173][01 01][00] v1.19.3422 -> v1.19.3422
[00007271][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007371][03 06][00] v2.3.0.13 -> v2.3.0.13
[00007422][04 00][00] v1.26.0.21 -> v1.26.0.21
[00007492][05 00][00] v3.0.6.1 -> v3.0.6.1
[00007552][08 00][00] v1.14.0.25 -> v1.14.0.25
[00007621][09 00][00] v1.8.0.0 -> v1.8.0.0
[00007710][11 00][00] v3.7.15.10 -> v3.7.15.10
[00007830][12 00][00] v1.8.0.0 -> v1.8.0.0
[00007950][12 01][00] v1.8.0.0 -> v1.8.0.0
[00008070][12 02][00] v1.8.0.0 -> v1.8.0.0
[00008230][12 03][00] v1.8.0.0 -> v1.8.0.0
[00008378][15 00][00] v1.1.2.0 -> v1.1.2.0
[00008471][17 00][00] v1.1.0.4 -> v1.1.0.4
[00008591][17 01][00] v2.0.0.8 -> v2.0.0.8
[00008655][19 00][00] v1.0.8.96 -> v1.0.8.96
[00010700]Packet upgrade cancelled at version checking.
[00004624]========== remo-con disconnect. boot(15) ============
[00004666]Packet [C:\WM610_FW_V01.04.00.10.bin] detected, card sn [0xbb4b2ace].
[00004711]Packet upgrade start...
[00004760]Packet checking...
[00004807]Packet vlink 01.04.0010 <-> 01.03.0000.
[00004850]Record vlink 01.04.0010 <-> 01.03.0000 (flow = 0).
[00004890]Done.
[00004937]Version checking[1]...
[00004979][01 00][00] v1.19.3422 -> v1.19.3422
[00005045][01 01][00] v1.19.3422 -> v1.19.3422
[00005133][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005233][03 06][00] v2.3.0.13 -> v2.3.0.13
[00005309][04 00][00] v1.26.0.21 -> v1.26.0.21
[00005393][05 00][00] v3.0.6.1 -> v3.0.6.1
[00005462][08 00][00] v1.14.0.25 -> v1.14.0.25
[00005549][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005613][11 00][00] v3.7.15.9 -> v3.7.15.10 need upgrade.
[00005714][12 00][00] v1.8.0.0 -> v1.8.0.0
[00005813][12 01][00] v1.8.0.0 -> v1.8.0.0
[00005914][12 02][00] v1.8.0.0 -> v1.8.0.0
[00006013][12 03][00] v1.8.0.0 -> v1.8.0.0
[00006191][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006254][17 00][00] v1.1.0.4 -> v1.1.0.4
[00006354][17 01][00] v2.0.0.8 -> v2.0.0.8
[00006409][19 00][00] v1.0.8.96 -> v1.0.8.96
[00006454]Done.
[00008502]Waiting for user confirm...
[00018545]Timeout, start upgrade automatically.
[00018628]Firmware upgrading[1]...
[00018689][11 00] Firmware upgrade start...
[00099444][11 00] Firmware upgrade finished successfully.
[00099487]Done.
[00099525]Version checking[2]...
[00099562][01 00][00] v1.19.3422 -> v1.19.3422
[00099599][01 01][00] v1.19.3422 -> v1.19.3422
[00099666][03 05][00] v34.1.0.5 -> v34.1.0.5
[00099750][03 06][00] v2.3.0.13 -> v2.3.0.13
[00099793][04 00][00] v1.26.0.21 -> v1.26.0.21
[00099865][05 00][00] v3.0.6.1 -> v3.0.6.1
[00099914][08 00][00] v1.14.0.25 -> v1.14.0.25
[00099976][09 00][00] v1.8.0.0 -> v1.8.0.0
[00100045][11 00][05] v3.7.15.10 -> v3.7.15.10
[00100145][12 00][00] v1.8.0.0 -> v1.8.0.0
[00100245][12 01][00] v1.8.0.0 -> v1.8.0.0
[00100345][12 02][00] v1.8.0.0 -> v1.8.0.0
[00100445][12 03][00] v1.8.0.0 -> v1.8.0.0
[00100540][15 00][00] v1.1.2.0 -> v1.1.2.0
[00100606][17 00][00] v1.1.0.4 -> v1.1.0.4
[00100706][17 01][00] v2.0.0.8 -> v2.0.0.8
[00100765][19 00][00] v1.0.8.96 -> v1.0.8.96
[00100802]Packet upgrade finish successfully.
[00004634]========== remo-con disconnect. boot(15) ============
[00004677]Packet [C:\WM610_FW_V01.06.00.40.bin] detected, card sn [0xbb4b2ace].
[00004717]Packet upgrade start...
[00004786]Packet checking...
[00004844]Packet vlink 01.06.0040 <-> 01.05.0030.
[00004910]Record vlink 01.04.0010 <-> 01.03.0000 (flow = 0).
[00004969]Done.
[00005032]Version checking[1]...
[00005092][01 00][00] v1.19.3422 -> v2.47.4492 need upgrade
[00005155][01 01][00] v1.19.3422 -> v2.47.4492 need upgrade
[00005261][03 05][00] v34.1.0.5 -> v34.1.0.5
[00005340][03 06][00] v2.3.0.13 -> v2.4.10.7 need upgrade.
[00005400][04 00][00] v1.26.0.21 -> v1.29.0.51 need upgrade.
[00005461][05 00][00] v3.0.6.1 -> v3.0.6.2 need upgrade.
[00005674][08 00][00] v1.14.0.25 -> v2.14.9.35 need upgrade.
[00005749][09 00][00] v1.8.0.0 -> v1.8.0.0
[00005820][11 00][00] v3.7.15.10 -> v3.8.15.4 need upgrade.
[00005919][12 00][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00006019][12 01][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00006102][12 02][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00006200][12 03][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00006300][15 00][00] v1.1.2.0 -> v1.1.2.0
[00006400][17 00][00] v1.1.0.4 -> v1.1.0.4
[00006520][17 01][00] v2.0.0.8 -> v2.0.1.2 need upgrade.
[00006582][19 00][00] v1.0.8.96 -> v1.0.8.96
[00006625]Done.
[00008668]Waiting for user confirm...
[00018727]Timeout, start upgrade automatically.
[00018819]Firmware upgrading[1]...
[00035881][01 00] Firmware upgrade start...
[00020496][01 00] Firmware upgrade finished successfully.
[00020613]Done.
[00020761]Packet [C:\WM610_FW_V01.06.00.40.bin] resumed, card sn [0xbb4b2ace].
[00020920]Packet vlink 01.06.0040 <-> 01.05.0030.
[00021084]Record vlink 01.04.0010 <-> 01.03.0000 (flow = 0).
[00021125]Version checking[2]...
[00021194][01 00][05] v2.47.4492 -> v2.47.4492
[00021314][01 01][00] v1.19.3422 -> v2.47.4492 need upgrade
[00021413][03 05][00] v34.1.0.5 -> v34.1.0.5
[00021513][03 06][00] v2.3.0.13 -> v2.4.10.7 need upgrade.
[00021603][04 00][00] v1.26.0.21 -> v1.29.0.51 need upgrade.
[00021713][05 00][00] v3.0.6.1 -> v3.0.6.2 need upgrade.
[00021760][08 00][00] v1.14.0.25 -> v2.14.9.35 need upgrade.
[00021815][09 00][00] v1.8.0.0 -> v1.8.0.0
[00021895][11 00][00] v3.7.15.10 -> v3.8.15.4 need upgrade.
[00021993][12 00][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00022073][12 01][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00022153][12 02][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00022233][12 03][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00023059][15 00][00] v1.1.2.0 -> v1.1.2.0
[00023134][17 00][00] v1.1.0.4 -> v1.1.0.4
[00023253][17 01][00] v2.0.0.8 -> v2.0.1.2 need upgrade.
[00023303][19 00][00] v1.0.8.96 -> v1.0.8.96
[00023426]Done.
[00023471]Firmware upgrading[2]...
[00023569][01 01] Firmware upgrade start...
[00033881][01 01] Firmware upgrade finished successfully.
[00034560][08 00] Firmware upgrade start...
[00618425][08 00] Firmware upgrade finished successfully.
[00618479][12 00] Firmware upgrade start...
[00656513][12 00] Firmware upgrade finished successfully.
[00656581][12 01] Firmware upgrade start...
[00694909][12 01] Firmware upgrade finished successfully.
[00694961][12 02] Firmware upgrade start...
[00733965][12 02] Firmware upgrade finished successfully.
[00734015][12 03] Firmware upgrade start...
[00772302][12 03] Firmware upgrade finished successfully.
[00772437][03 06] Firmware upgrade start...
[00992802][03 06] Firmware upgrade finished successfully.
[00992853][17 01] Firmware upgrade start...
[01026599][17 01] Firmware upgrade finished successfully.
[01026650][11 00] Firmware upgrade start...
[01093194][11 00] Firmware upgrade finished successfully.
[01093246][05 00] Firmware upgrade start...
[01118630][05 00] Firmware upgrade finished successfully.
[01118702][04 00] Firmware upgrade start...
[01167249][04 00] Firmware upgrade finished successfully.
[01167290]Done.
[01167334]Version checking[3]...
[01167375][01 00][05] v2.47.4492 -> v2.47.4492
[01167415][01 01][05] v2.47.4492 -> v2.47.4492
[01167529][03 05][00] v34.1.0.5 -> v34.1.0.5
[01167589][03 06][05] v2.4.10.7 -> v2.4.10.7
[01167635][04 00][05] v1.29.0.51 -> v1.29.0.51
[01167729][05 00][05] v3.0.6.2 -> v3.0.6.2
[01167777][08 00][05] v2.14.9.35 -> v2.14.9.35
[01167829][09 00][00] v1.8.0.0 -> v1.8.0.0
[01167909][11 00][05] v3.8.15.4 -> v3.8.15.4
[01168009][12 00][05] v1.11.0.0 -> v1.11.0.0
[01168109][12 01][05] v1.11.0.0 -> v1.11.0.0
[01168209][12 02][05] v1.11.0.0 -> v1.11.0.0
[01168309][12 03][05] v1.11.0.0 -> v1.11.0.0
[01168417][15 00][00] v1.1.2.0 -> v1.1.2.0
[01168529][17 00][00] v1.1.0.4 -> v1.1.0.4
[01168629][17 01][05] v2.0.1.2 -> v2.0.1.2
[01168788][19 00][00] v1.0.8.96 -> v1.0.8.96
[01168833]Packet upgrade finish successfully.
[00008507]========== remo-con disconnect. boot(15) ============
[00008556]Packet [C:\WM610_FW_V01.06.00.40.bin] detected, card sn [0xbb4b2ace].
[00008619]Packet upgrade start...
[00008681]Packet checking...
[00008733]Packet vlink 01.06.0040 <-> 01.05.0030.
[00008773]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00008821]Done.
[00008864]Version checking[1]...
[00008904][01 00][00] v2.47.4492 -> v2.47.4492
[00008944][01 01][00] v2.47.4492 -> v2.47.4492
[00009014][03 05][00] v34.1.0.5 -> v34.1.0.5
[00009114][03 06][00] v2.4.10.7 -> v2.4.10.7
[00009168][04 00][00] v1.29.0.51 -> v1.29.0.51
[00009254][05 00][00] v3.0.6.2 -> v3.0.6.2
[00009305][08 00][00] v2.14.9.35 -> v2.14.9.35
[00009354][09 00][00] v1.8.0.0 -> v1.8.0.0
[00009434][11 00][00] v3.7.15.10 -> v3.8.15.4 need upgrade.
[00009534][12 00][00] v1.11.0.0 -> v1.11.0.0
[00009634][12 01][00] v1.11.0.0 -> v1.11.0.0
[00009735][12 02][00] v1.11.0.0 -> v1.11.0.0
[00009834][12 03][00] v1.11.0.0 -> v1.11.0.0
[00009942][15 00][00] v1.1.2.0 -> v1.1.2.0
[00010014][17 00][00] v1.1.0.4 -> v1.1.0.4
[00010134][17 01][00] v2.0.1.2 -> v2.0.1.2
[00010186][19 00][00] v1.0.8.96 -> v1.0.8.96
[00010226]Done.
[00012282]Waiting for user confirm...
[00022327]Timeout, start upgrade automatically.
[00022414]Firmware upgrading[1]...
[00022463][11 00] Firmware upgrade start...
[00088604][11 00] Firmware upgrade finished successfully.
[00088646]Done.
[00088686]Version checking[2]...
[00088728][01 00][00] v2.47.4492 -> v2.47.4492
[00088775][01 01][00] v2.47.4492 -> v2.47.4492
[00088847][03 05][00] v34.1.0.5 -> v34.1.0.5
[00088927][03 06][00] v2.4.10.7 -> v2.4.10.7
[00088975][04 00][00] v1.29.0.51 -> v1.29.0.51
[00089047][05 00][00] v3.0.6.2 -> v3.0.6.2
[00089094][08 00][00] v2.14.9.35 -> v2.14.9.35
[00089147][09 00][00] v1.8.0.0 -> v1.8.0.0
[00089227][11 00][05] v3.8.15.4 -> v3.8.15.4
[00089427][12 00][00] v1.11.0.0 -> v1.11.0.0
[00089546][12 01][00] v1.11.0.0 -> v1.11.0.0
[00089647][12 02][00] v1.11.0.0 -> v1.11.0.0
[00089748][12 03][00] v1.11.0.0 -> v1.11.0.0
[00091015][15 00][00] v1.1.2.0 -> v1.1.2.0
[00091087][17 00][00] v1.1.0.4 -> v1.1.0.4
[00091187][17 01][00] v2.0.1.2 -> v2.0.1.2
[00091238][19 00][00] v1.0.8.96 -> v1.0.8.96
[00091284]Packet upgrade finish successfully.
[00007167]========== remo-con disconnect. boot(15) ============
[00007314]Packet [C:\WM610_FW_V01.07.00.90.bin] detected, card sn [0x01be9318].
[00007429]Packet upgrade start...
[00007571]Packet checking...
[00007716]Packet vlink 01.07.0090 <-> 01.06.0040.
[00007870]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00007940]Done.
[00007986]Version checking[1]...
[00008114][01 00][00] v2.47.4492 -> v2.63.4998 need upgrade
[00008177][01 01][00] v2.47.4492 -> v2.63.4998 need upgrade
[00008271][03 05][00] v34.1.0.5 -> v34.1.0.5
[00008351][03 06][00] v2.4.10.7 -> v2.4.10.7
[00008417][04 00][00] v1.29.0.51 -> v1.29.0.91 need upgrade.
[00008511][05 00][00] v3.0.6.2 -> v3.0.6.2
[00008564][08 00][00] v2.14.9.35 -> v2.14.9.42 need upgrade.
[00008617][09 00][00] v1.8.0.0 -> v1.8.0.0
[00008731][11 00][00] v3.8.15.4 -> v3.8.15.4
[00008811][12 00][00] v1.11.0.0 -> v1.11.0.0
[00008931][12 01][00] v1.11.0.0 -> v1.11.0.0
[00009011][12 02][00] v1.11.0.0 -> v1.11.0.0
[00009111][12 03][00] v1.11.0.0 -> v1.11.0.0
[00009225][15 00][00] v1.1.2.0 -> v1.1.2.0
[00009311][17 00][00] v1.1.0.4 -> v1.1.0.4
[00009411][17 01][00] v2.0.1.2 -> v2.0.1.2
[00009480][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009524]Done.
[00011582]Waiting for user confirm...
[00021625]Timeout, start upgrade automatically.
[00021713]Firmware upgrading[1]...
[00027175][01 00] Firmware upgrade start...
[00020977][01 00] Firmware upgrade finished successfully.
[00021023]Done.
[00021069]Packet [C:\WM610_FW_V01.07.00.90.bin] resumed, card sn [0x01be9318].
[00021128]Packet vlink 01.07.0090 <-> 01.06.0040.
[00021271]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00021315]Version checking[2]...
[00021369][01 00][05] v2.63.4998 -> v2.63.4998
[00021419][01 01][00] v2.47.4492 -> v2.63.4998 need upgrade
[00021506][03 05][00] v34.1.0.5 -> v34.1.0.5
[00021606][03 06][00] v2.4.10.7 -> v2.4.10.7
[00021660][04 00][00] v1.29.0.51 -> v1.29.0.91 need upgrade.
[00021746][05 00][00] v3.0.6.2 -> v3.0.6.2
[00021798][08 00][00] v2.14.9.35 -> v2.14.9.42 need upgrade.
[00021857][09 00][00] v1.8.0.0 -> v1.8.0.0
[00021947][11 00][00] v3.8.15.4 -> v3.8.15.4
[00022027][12 00][00] v1.11.0.0 -> v1.11.0.0
[00022107][12 01][00] v1.11.0.0 -> v1.11.0.0
[00022207][12 02][00] v1.11.0.0 -> v1.11.0.0
[00022307][12 03][00] v1.11.0.0 -> v1.11.0.0
[00023631][15 00][00] v1.1.2.0 -> v1.1.2.0
[00023706][17 00][00] v1.1.0.4 -> v1.1.0.4
[00023826][17 01][00] v2.0.1.2 -> v2.0.1.2
[00023888][19 00][00] v1.0.8.96 -> v1.0.8.96
[00023947]Done.
[00023998]Firmware upgrading[2]...
[00024098][01 01] Firmware upgrade start...
[00034381][01 01] Firmware upgrade finished successfully.
[00035081][08 00] Firmware upgrade start...
[00500556][08 00] Firmware upgrade finished successfully.
[00500630][04 00] Firmware upgrade start...
[00553856][04 00] Firmware upgrade finished successfully.
[00553908]Done.
[00553959]Version checking[3]...
[00554003][01 00][05] v2.63.4998 -> v2.63.4998
[00554051][01 01][05] v2.63.4998 -> v2.63.4998
[00554137][03 05][00] v34.1.0.5 -> v34.1.0.5
[00554237][03 06][00] v2.4.10.7 -> v2.4.10.7
[00554290][04 00][05] v1.29.0.91 -> v1.29.0.91
[00554397][05 00][00] v3.0.6.2 -> v3.0.6.2
[00554463][08 00][05] v2.14.9.42 -> v2.14.9.42
[00554518][09 00][00] v1.8.0.0 -> v1.8.0.0
[00554618][11 00][00] v3.8.15.4 -> v3.8.15.4
[00554718][12 00][00] v1.11.0.0 -> v1.11.0.0
[00554818][12 01][00] v1.11.0.0 -> v1.11.0.0
[00554918][12 02][00] v1.11.0.0 -> v1.11.0.0
[00555038][12 03][00] v1.11.0.0 -> v1.11.0.0
[00555142][15 00][00] v1.1.2.0 -> v1.1.2.0
[00555298][17 00][00] v1.1.0.4 -> v1.1.0.4
[00555419][17 01][00] v2.0.1.2 -> v2.0.1.2
[00555486][19 00][00] v1.0.8.96 -> v1.0.8.96
[00555532]Packet upgrade finish successfully.
[00007096]========== remo-con disconnect. boot(15) ============
[00007190]Packet [C:\WM610_FW_V01.07.00.90.bin] detected, card sn [0xbb4b2ace].
[00007252]Packet upgrade start...
[00007303]Packet checking...
[00007360]Packet vlink 01.07.0090 <-> 01.06.0040.
[00007413]Record vlink 01.07.0090 <-> 01.06.0040 (flow = 0).
[00007459]Done.
[00007507]Version checking[1]...
[00007557][01 00][00] v2.63.4998 -> v2.63.4998
[00007602][01 01][00] v2.63.4998 -> v2.63.4998
[00007689][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007770][03 06][00] v2.4.10.7 -> v2.4.10.7
[00007826][04 00][00] v1.29.0.91 -> v1.29.0.91
[00007913][05 00][00] v3.0.6.2 -> v3.0.6.2
[00007971][08 00][00] v2.14.9.42 -> v2.14.9.42
[00008034][09 00][00] v1.8.0.0 -> v1.8.0.0
[00008130][11 00][00] v3.8.15.4 -> v3.8.15.4
[00008250][12 00][00] v1.11.0.0 -> v1.11.0.0
[00008350][12 01][00] v1.11.0.0 -> v1.11.0.0
[00008449][12 02][00] v1.11.0.0 -> v1.11.0.0
[00008553][12 03][00] v1.11.0.0 -> v1.11.0.0
[00008664][15 00][00] v1.1.2.0 -> v1.1.2.0
[00008729][17 00][00] v1.1.0.4 -> v1.1.0.4
[00008869][17 01][00] v2.0.1.2 -> v2.0.1.2
[00008929][19 00][00] v1.0.8.96 -> v1.0.8.96
[00010986]Packet upgrade cancelled at version checking.
[00007535]========== remo-con disconnect. boot(15) ============
[00007624]Packet [C:\WM610_FW_V01.06.00.40.bin] detected, card sn [0x01be9318].
[00007701]Packet upgrade start...
[00007761]Packet checking...
[00007812]Packet vlink 01.06.0040 <-> 01.05.0030.
[00007863]Record vlink 01.07.0090 <-> 01.06.0040 (flow = 1).
[00007912]Done.
[00007960]Version checking[1]...
[00008013][01 00][00] v2.63.4998 -> v2.47.4492 need upgrade
[00008062][01 01][00] v2.63.4998 -> v2.47.4492 need upgrade
[00008150][03 05][00] v34.1.0.5 -> v34.1.0.5
[00008225][03 06][00] v2.4.10.7 -> v2.4.10.7
[00008385][04 00][00] v1.29.0.91 -> v1.29.0.51 need upgrade.
[00008446][05 00][00] v3.0.6.2 -> v3.0.6.2
[00008511][08 00][00] v2.14.9.42 -> v2.14.9.35 need upgrade.
[00008570][09 00][00] v1.8.0.0 -> v1.8.0.0
[00008651][11 00][00] v3.8.15.4 -> v3.8.15.4
[00008765][12 00][00] v1.11.0.0 -> v1.11.0.0
[00008865][12 01][00] v1.11.0.0 -> v1.11.0.0
[00008965][12 02][00] v1.11.0.0 -> v1.11.0.0
[00009065][12 03][00] v1.11.0.0 -> v1.11.0.0
[00009172][15 00][00] v1.1.2.0 -> v1.1.2.0
[00009246][17 00][00] v1.1.0.4 -> v1.1.0.4
[00009365][17 01][00] v2.0.1.2 -> v2.0.1.2
[00009424][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009480]Done.
[00011541]Waiting for user confirm...
[00021594]Timeout, start upgrade automatically.
[00021695]Firmware upgrading[1]...
[00021790][01 01] Firmware upgrade start...
[00032059][01 01] Firmware upgrade finished successfully.
[00032650][08 00] Firmware upgrade start...
[00499818][08 00] Firmware upgrade finished successfully.
[00499885][04 00] Firmware upgrade start...
[00552529][04 00] Firmware upgrade finished successfully.
[00552574]Done.
[00552627]Version checking[2]...
[00552688][01 00][00] v2.63.4998 -> v2.47.4492 need upgrade
[00552736][01 01][05] v2.47.4492 -> v2.47.4492
[00552835][03 05][00] v34.1.0.5 -> v34.1.0.5
[00552935][03 06][00] v2.4.10.7 -> v2.4.10.7
[00553000][04 00][05] v1.29.0.51 -> v1.29.0.51
[00553095][05 00][00] v3.0.6.2 -> v3.0.6.2
[00553144][08 00][05] v2.14.9.35 -> v2.14.9.35
[00553205][09 00][00] v1.8.0.0 -> v1.8.0.0
[00553335][11 00][00] v3.8.15.4 -> v3.8.15.4
[00553434][12 00][00] v1.11.0.0 -> v1.11.0.0
[00553534][12 01][00] v1.11.0.0 -> v1.11.0.0
[00553634][12 02][00] v1.11.0.0 -> v1.11.0.0
[00553734][12 03][00] v1.11.0.0 -> v1.11.0.0
[00555013][15 00][00] v1.1.2.0 -> v1.1.2.0
[00555095][17 00][00] v1.1.0.4 -> v1.1.0.4
[00555215][17 01][00] v2.0.1.2 -> v2.0.1.2
[00555309][19 00][00] v1.0.8.96 -> v1.0.8.96
[00555359]Done.
[00555407]Firmware upgrading[2]...
[00561716][01 00] Firmware upgrade start...
[00018896][01 00] Firmware upgrade finished successfully.
[00019007]Done.
[00019181]Packet [C:\WM610_FW_V01.06.00.40.bin] resumed, card sn [0x01be9318].
[00019277]Packet vlink 01.06.0040 <-> 01.05.0030.
[00019388]Record vlink 01.07.0090 <-> 01.06.0040 (flow = 1).
[00019440]Version checking[2]...
[00019489][01 00][05] v2.47.4492 -> v2.47.4492
[00019585][01 01][05] v2.47.4492 -> v2.47.4492
[00019728][03 05][00] v34.1.0.5 -> v34.1.0.5
[00019834][03 06][00] v2.4.10.7 -> v2.4.10.7
[00019937][04 00][05] v1.29.0.51 -> v1.29.0.51
[00020048][05 00][00] v3.0.6.2 -> v3.0.6.2
[00020102][08 00][05] v2.14.9.35 -> v2.14.9.35
[00020163][09 00][00] v1.8.0.0 -> v1.8.0.0
[00020269][11 00][00] v3.8.15.4 -> v3.8.15.4
[00020373][12 00][00] v1.11.0.0 -> v1.11.0.0
[00020468][12 01][00] v1.11.0.0 -> v1.11.0.0
[00020568][12 02][00] v1.11.0.0 -> v1.11.0.0
[00020687][12 03][00] v1.11.0.0 -> v1.11.0.0
[00021529][15 00][00] v1.1.2.0 -> v1.1.2.0
[00021608][17 00][00] v1.1.0.4 -> v1.1.0.4
[00021728][17 01][00] v2.0.1.2 -> v2.0.1.2
[00021788][19 00][00] v1.0.8.96 -> v1.0.8.96
[00021838]Packet upgrade finish successfully.
[00007382]========== remo-con disconnect. boot(15) ============
[00007534]Packet [C:\WM610_FW_V01.07.00.90.bin] detected, card sn [0x01be9318].
[00007682]Packet upgrade start...
[00007828]Packet checking...
[00007932]Packet vlink 01.07.0090 <-> 01.06.0040.
[00008044]Record vlink 01.07.0090 <-> 01.06.0040 (flow = 0).
[00008093]Done.
[00008207]Version checking[1]...
[00008333][01 00][00] v2.47.4492 -> v2.63.4998 need upgrade
[00008389][01 01][00] v2.47.4492 -> v2.63.4998 need upgrade
[00008459][03 05][00] v34.1.0.5 -> v34.1.0.5
[00008539][03 06][00] v2.4.10.7 -> v2.4.10.7
[00008605][04 00][00] v1.29.0.51 -> v1.29.0.91 need upgrade.
[00008679][05 00][00] v3.0.6.2 -> v3.0.6.2
[00008742][08 00][00] v2.14.9.35 -> v2.14.9.42 need upgrade.
[00008809][09 00][00] v1.8.0.0 -> v1.8.0.0
[00008919][11 00][00] v3.8.15.4 -> v3.8.15.4
[00009160][12 00][00] v1.11.0.0 -> v1.11.0.0
[00009278][12 01][00] v1.11.0.0 -> v1.11.0.0
[00009378][12 02][00] v1.11.0.0 -> v1.11.0.0
[00009478][12 03][00] v1.11.0.0 -> v1.11.0.0
[00009589][15 00][00] v1.1.2.0 -> v1.1.2.0
[00009679][17 00][00] v1.1.0.4 -> v1.1.0.4
[00009799][17 01][00] v2.0.1.2 -> v2.0.1.2
[00009863][19 00][00] v1.0.8.96 -> v1.0.8.96
[00009912]Done.
[00011980]Waiting for user confirm...
[00022029]Timeout, start upgrade automatically.
[00022134]Firmware upgrading[1]...
[00027949][01 00] Firmware upgrade start...
[00020982][01 00] Firmware upgrade finished successfully.
[00021032]Done.
[00021086]Packet [C:\WM610_FW_V01.07.00.90.bin] resumed, card sn [0x01be9318].
[00021149]Packet vlink 01.07.0090 <-> 01.06.0040.
[00021199]Record vlink 01.07.0090 <-> 01.06.0040 (flow = 0).
[00021252]Version checking[2]...
[00021300][01 00][05] v2.63.4998 -> v2.63.4998
[00021357][01 01][00] v2.47.4492 -> v2.63.4998 need upgrade
[00021440][03 05][00] v34.1.0.5 -> v34.1.0.5
[00021521][03 06][00] v2.4.10.7 -> v2.4.10.7
[00021588][04 00][00] v1.29.0.51 -> v1.29.0.91 need upgrade.
[00021680][05 00][00] v3.0.6.2 -> v3.0.6.2
[00021737][08 00][00] v2.14.9.35 -> v2.14.9.42 need upgrade.
[00021813][09 00][00] v1.8.0.0 -> v1.8.0.0
[00021900][11 00][00] v3.8.15.4 -> v3.8.15.4
[00022020][12 00][00] v1.11.0.0 -> v1.11.0.0
[00022120][12 01][00] v1.11.0.0 -> v1.11.0.0
[00022220][12 02][00] v1.11.0.0 -> v1.11.0.0
[00022320][12 03][00] v1.11.0.0 -> v1.11.0.0
[00023642][15 00][00] v1.1.2.0 -> v1.1.2.0
[00023720][17 00][00] v1.1.0.4 -> v1.1.0.4
[00023848][17 01][00] v2.0.1.2 -> v2.0.1.2
[00023910][19 00][00] v1.0.8.96 -> v1.0.8.96
[00023963]Done.
[00024012]Firmware upgrading[2]...
[00024118][01 01] Firmware upgrade start...
[00034406][01 01] Firmware upgrade finished successfully.
[00035104][08 00] Firmware upgrade start...
[00501201][08 00] Firmware upgrade finished successfully.
[00501273][04 00] Firmware upgrade start...
[00554428][04 00] Firmware upgrade finished successfully.
[00554570]Done.
[00554625]Version checking[3]...
[00554686][01 00][05] v2.63.4998 -> v2.63.4998
[00554734][01 01][05] v2.63.4998 -> v2.63.4998
[00554831][03 05][00] v34.1.0.5 -> v34.1.0.5
[00554917][03 06][00] v2.4.10.7 -> v2.4.10.7
[00555007][04 00][05] v1.29.0.91 -> v1.29.0.91
[00555091][05 00][00] v3.0.6.2 -> v3.0.6.2
[00555173][08 00][05] v2.14.9.42 -> v2.14.9.42
[00555236][09 00][00] v1.8.0.0 -> v1.8.0.0
[00555331][11 00][00] v3.8.15.4 -> v3.8.15.4
[00555451][12 00][00] v1.11.0.0 -> v1.11.0.0
[00555551][12 01][00] v1.11.0.0 -> v1.11.0.0
[00555651][12 02][00] v1.11.0.0 -> v1.11.0.0
[00555751][12 03][00] v1.11.0.0 -> v1.11.0.0
[00555864][15 00][00] v1.1.2.0 -> v1.1.2.0
[00555932][17 00][00] v1.1.0.4 -> v1.1.0.4
[00556072][17 01][00] v2.0.1.2 -> v2.0.1.2
[00556136][19 00][00] v1.0.8.96 -> v1.0.8.96
[00556191]Packet upgrade finish successfully
2016-3-21
patrickdiddly
Another hurdle right there my laptop wont let me unzip files? thanks for doing your best for me Donnie
i need some sleep now tommorow is another day......
2016-3-21
Donnie
patrickdiddly@a Posted at 2016-3-21 16:02
Another hurdle right there my laptop wont let me unzip files? thanks for doing your best for me D ...
Ok another forum member who has your same system just posted  this and it fixed his 2 RC transmitters.  Give it a go Please Patrick.......... Make sure you are connected to the RC with a cable to the i-pad or whatever.   here is the whole post: Might need extra set of hands also                ***My additons are bold black
Make sure that everything is switched off except the phone ( whatever device has go app ) but make sure that the Go App is not running on the background
Make sure the the Go App is the default app that will always start when the transmitter is switched on ( Just make sure you can get to it quickly, as I dont understand that part)
Press C1, C2, record and the wheel on the right side of thetransmitter  and then turn ON the transmitter  and hold the buttons in until the app starts up.
Open the aircraft Status and click on the upgrade link.
The transmitter will disconnect from the device, thats what I thought, but if you just leave the transmitter on, it starts to update very very slowly.
The upgrade then runs for about 40 min and at the end the green light comes on.
I have done this with both the controllers and they are now working.
I have noticed the following:
If I plug my device into the controller and switch it on nothing happens. I have to switch the controller on first and then plug the device in. You can ask your developers to check the initial state for the USB port of the controller when you switch it on, I think they have slipped up on setting the initial state to active.
2016-3-22
patrickdiddly
Donnie Posted at 2016-3-22 13:26
Ok another forum member who has your same system just posted  this and it fixed his 2 RC transmitte ...
Just tried this no luck??
2016-3-22
Donnie
   You could just download the BIN file of firmware 1.3  on the Inspire downloads page. Then use a thumb drive to load that to your transmitters, then upgrade to 1.5. 80
Give it a shot -donnie
2016-3-22
patrickdiddly
Donnie Posted at 2016-3-22 16:10
You could just download the BIN file of firmware 1.3  on the Inspire downloads page. Then use a t ...
Cant unzip files on my locked down lappy....... think i will just bin it!
2016-3-22
Donnie
patrickdiddly@a Posted at 2016-3-22 12:02
I asked one of the other forum members and they were nice enough to write this down , maybe follow  step by step ( His transmitter was just like yours )- Donnie
Follow these steps, please read them carefully.
Step 1:
Make sure that everything is switched off except the phone and make sure that the Go App is not running in the background
Step 2:
Make sure the the Go App is the default app that will always start when the controller is switched on. (Read at the explanation above)
Step 3:
Press C1, C2, record and the wheel on the right side of the controller and then turn ON the controller and hold the buttons in until the Go App starts up. You can now let go of the buttons.
!! THIS STEP IS VERY IMPORTANT !!
Step 4:
Open the Aircraft Status in the Go App. You will see that the app will tell you that you need to upgrade the firmware. Open the upgrade area and click on the upgrade link.
Step 5:
The controller will disconnect from the device but will connect again if you just leave the controller on and the Go App open in the same screen in Step 4, the upgrade will start to update very very slowly.
Step 6:
It is very important that you follow these steps  and not close the Go App or switch your controller off until you get to the end of step 6.
!! You must have patience and just wait !!
I hope that this will help. I had to do this with two controllers that had the same problem and it worked for both of them. It took me about a day to get the steps 100% after DJI said that the controller is faulty and I need to return it for repair.   How stupid do they think we are, what is the chance of two controllers going faulty on the same day in a span of one hour and this after I did an update that they said I needed to do......
Raymond
2016-3-22
patrickdiddly
Donnie Posted at 2016-3-22 22:02
I asked one of the other forum members and they were nice enough to write this down , maybe follow ...
This does not work for me???
2016-3-22
marcsobel
If your control is bricked then put this https://dl.djicdn.com/downloads/RC/C1_FW_V01.05.0080.bin on a USB stick and plug it into the controller.
2016-3-22
patrickdiddly
patrickdiddly@a Posted at 2016-3-22 22:34
Tried it all now even bought winzip tonight £31 wasted also bought a new lappy of my own £299 what a waste of money well disappointed with Dji!
2016-3-22
dronemovie
Brazil
patrickdiddly@a Posted at 2016-3-22 03:20
good night I'm having the same problem my rc this locked and not connect more with all this aircraft after upgrading the dji -go app did and gave eero in the end, if you know how to fix thank you thank you.
2016-3-22
patrickdiddly
dronemovie Posted at 2016-3-23 00:19
good night I'm having the same problem my rc this locked and not connect more with all this aircra ...
Wish i did Dronemovie....sick to death of it at this stage, i wont be buying another Dji product!
2016-3-22
patrickdiddly
patrickdiddly@a Posted at 2016-3-23 06:26
I have some good news...i downgraded inspire then upgraded again, then on app where it says no connection or disconnected i clicked there and it said update required! cont 1 took around 15 mins con 2 about 3.,
i can connect using con 1 so that will do for me! Thanks to all that helped on here very much appreciated!
Fly safe
Pat.
2016-3-23
Donnie
patrickdiddly@a Posted at 2016-3-22 17:48
Tried it all now even bought winzip tonight £31 wasted also bought a new lappy of my own £299 wh ...
I can just send you the Bin File only if that helps,  My e-mail is  donaldjames1990@gmail.com   if you send me  an  e-mail   ( I hope you have google mail , works best with large files ) I will send it to you, with the bin file already for install.
Did you JUST buy this  where you could return it without to much drama ?  If so that might be an option as well.
****Just so you know the log File shows success with the aircraft loaded with 1.7.  It is the Transmitter that did not get a proper firmware upload ( I am sure you figured this out )
good luck - donnie
2016-3-23
Donnie
patrickdiddly@a Posted at 2016-3-22 17:34
The reason I posted this was it was in more detail and I thought there may have been a step in there that may have been overlooked.    I am glad you have one working, you will get the other one going soon I imagine as well.
Cheers from the Jolly- Old USA-  donnie
2016-3-23
