Donnie
Flight distance : 3636782 ft
Where did you get the remote from ? It should have at least 1.3 on it . ( It cant have NO firmware on it , it have something to default to ) Can you connect Your RC transmitter to The Go app device and when you connect tap on the top corner you will see a graduation cap, hold it in for about 8 -10 seconds and let go . It will tell you what version the RC is currently on . Then we can go from there . It is a simple update from here if you wish.
While doing this make sure
Aircraft is off
You have a strong wi fi connection to the Go App device . After you attempted to download with a thumb drive be sure to check the thumb drive afterwards for a report, it should say "success" or Abort Or whatever, we need to see the result of that istall afterwards, that way you know where you stand.
When you tried with a thumb drive loading 1.3 or 1.6 did you do the following :
You are only loading the BIN file to the thumb drive correct, this is very important, the RC when the thumb drive is loaded will be off , then with the bin file of 1.3 loaded you turn on the RC, you should see a blue light and at the end will turn greem takes about 10 -20 min.
donnie
Below is a sample video of the procedure .
I can get you 1.2 but lets start with the above for now . I just did this to my new transmitter ( For slave purposes, bought it off internet ) so know what you are going through, my sense is the transmitter has at least 1.3 and we must update from there , or at least 1.2 and 1.3 should have loaded.
