Punchbuggy
Flight distance : 483166 ft
Flytcam_Shaun Posted at 2017-4-23 23:17
Would you suggest this if the gimbal still tilts in the wind at high speeds tracking sideways? My gimbal does this on a second aircraft that i just exchanged. I have seen a little horizon tilt before on other DJI gear, but nowhere near as bad as what I am getting on two separate aircraft.
Sorry, but this procedure is to resolve the gimbal not sitting perfectly centre in its power-down state. I understand, typically caused by bumps in transit.
When the craft is powered on, it's motor and sensor driven from that point (with settings baselined via IMU and gimbal calibration). I'd suggest this is the operation you need to get perfect, from what you described (noting that most P4s have horizon tilt issues as at the current firmware). |
