DO NOT BUY AN OTG CABLE FOR SPARK!!
303785 303785 2018-1-22
philjones93
Flight distance : 4715 ft
I recently bought a DJI Spark and after watching loads of videos about it I noticed something called an OTG cable, in reviews it stated that it increased flight distance and video transmission.
After buying one and using it over the past weekend I have realised that they DO NOT WORK AT ALL!!!
Image one; is a screenshot with the OTG cable plugged in.
Image two; is a screenshot with no OTG cable plugged in and only connected via the remote Wi-Fi.
As you can see image one I am getting 0 or N/A read-outs and the map isn't showing properly. Image one all the reading are showing again and the map is working properly. Also I noticed when the OTG cable is plugged in the obstacle avoidance feature disables itself.
PLEASE DO NOT BUY OR USE AN OTG CABLE! I got lucky while using mine but it could have been a lot worse.
Thanks,
Phil Jones
*you can check out and subscribe to my YouTube channel here: https://www.youtube.com/user/PhilJones93 **
2018-1-22
philjones93
**Image two; is a screenshot with the OTG cable unplugged and only connected via the remote Wi-Fi. **
**Image two all the reading are...**
2018-1-22
teknikal90
Flight distance : 106601 ft
sure, but hows the lag in the video when connected via OTG vs not? like, try waving your hand in front of the camera and seeing the delay.
2018-1-22
Arcicorsa
Flight distance : 235892 ft
Czechia
WoW !! You discovered the wheel..
https://forum.dji.com/thread-124512-1-3.html
https://forum.dji.com/thread-121786-1-4.html
https://forum.dji.com/thread-129145-1-10.html
etc..
2018-1-22
A CW
Flight distance : 14588274 ft
teknikal90 Posted at 2018-1-22 12:02
I find it's over a second. With my Mavic it's practically instant. The lag on the Spark is slow.
2018-1-22
teknikal90
A CW Posted at 2018-1-22 12:08
with the OTG cable, it's also practically instant
2018-1-22
Grmachine
If it’s any consolation, it is a known issue, and they say it’s being worked, but in the meantime, it’s recommended not to use OTG.
2018-1-22
A CW
teknikal90 Posted at 2018-1-22 12:15
I know - but isn't there a big issue that they are not supported at present?
2018-1-22
fansbfe49189
Flight distance : 198061 ft
Costa Rica
Same problem, otg cable dont give me info, battery or GPS, spark with android 7.0
2018-1-22
FatherXmas
Flight distance : 4058619 ft
OTG isn't supported, never was. It was an accident that it worked to begin with. The last I've read from the DJI folks is that there's currently no plan to make it work.
2018-1-22
web_parrot
Flight distance : 23625 ft
Please perform a "Search" on OTG.... there are numerous threads on the topic with endless opinions offered on whether it's an abandoned option, intentional throttling, or alien invasion.
2018-1-22
Wachtberger
Flight distance : 261509 ft
Sometimes it really helps to take the time reading at bit across this wonderful forum ;-)
2018-1-22
teknikal90
FatherXmas Posted at 2018-1-22 13:41
where did you read that? I thought DJI engineers are working on it?
2018-1-22
Lis Morris
web_parrot Posted at 2018-1-22 13:55
Definitely the third of those options. It's just common sense
2018-1-22
philjones93
There are some very rude comments as a reply to my post...it was a simple mistake to use an OTG cable and reading isn't my strong point I prefer videos to reading...Thanks for the tips and advice though, I hope my post helps other people that may be starting off like myself.
2018-1-22
FatherXmas
teknikal90 Posted at 2018-1-22 14:22
Search for OTG on this forum, many many threads about it with comments from the DJI admins.
2018-1-22
teknikal90
FatherXmas Posted at 2018-1-22 15:19
they all seem to say 'OTG is not fully tested. our engineers are working on it.'
2018-1-22
FatherXmas
teknikal90 Posted at 2018-1-22 16:08
May be recent replies then, I admit I've pretty much stopped reading most of the OTG threads.
2018-1-22
rushiano
Flight distance : 122743 ft
Argentina
Hello, I bought an OTG cable for my Spark, and with the lastest version of DJI GO 4 (4.1.22) the screen was the same as the OP's first image. I read through another posts and I downgraded the app to 4.1.14, and now it works perfectly, I have all the information (batt, sats, telemetry, moving map, flight path), and it detects when takeoff and landing. You can find the installer in apkmirror website (dji.go.v4_4.1.14-1027326_minAPI19(armeabi-v7a)(nodpi)_apkmirror.com.apk).
Hope this helps.
Regards,
2018-1-22
rushiano
Argentina
rushiano Posted at 2018-1-22 17:44
Hope this helps.
Regards,
PS: I have a Moto Z Play and I can't use it via WiFi, it's very unstable, I lose the signal all the time (but the connection between RC and aircraft is stable). Curiously, if I connect my phone directly to the aircraft, it works fine (but why having an RC and not being able to use it?). So the OTG was my last hope, and luckily it works for me.
2018-1-22
fans24d1276b
Flight distance : 245433 ft
It’s sad that we have to go though this again and again. I really hope that they are working on it.
2018-1-22
fansa6d9d300
fans24d1276b Posted at 2018-1-22 18:17
yea! for the new one.
2018-1-22
DJI Elektra
Sir, please use wifi connection instead. OTG cable is not fully tested. Thanks for your understanding.
2018-1-27
djiuser_lKKcB0k
Flight distance : 264495 ft
DJI Elektra Posted at 2018-1-27 01:35
Hello. What you write is right, but we should know if DJI will soon be able to connect the spark via OTG. At the moment I would not advise anyone to buy it because it is too important to have an image without delays on the Android smartphone, especially for security reasons. Please tell your managers again.
2018-1-27
spookster
Flight distance : 419649 ft
But I need OTG for spark and goggles. Also it is nice to connect usb sticks to phone or a go mic or other stuff :-) for use with spark remte we have to wait until dji supports it.
2018-1-27
humpataa
Flight distance : 41247 ft
Even a video of DJI is using a OTG cable with the spark. So what are you guys talking about? It IS supported and it IS working:
2018-1-27
Arcicorsa
Czechia
humpataa Posted at 2018-1-27 09:16
https://youtu.be/mo1ki0_SfF4?t=1m5s
Of course OTG works (with app 4.1.15), only DJI has decided to ban it from business interests..
2018-1-27
Eduardo0
Flight distance : 6443990 ft
I am to the latest software released and OTG works fine for me. I have often tried WIFI but almost always I get frustrated. OTG is the way to go for me.
2018-1-27
eman_vg
Flight distance : 1015440 ft
I have thought OTG cables did something good for the spark. But after flying with it, I realized that it is not supported at all, the craft disconnects occasionally when not connected to RC wifi.
2018-1-27
Pappy3
Flight distance : 2820469 ft
Well, at least DJI got it right the first time with the Mavic Air RC and smartphone/tablet. It uses "enhanced" wifi and a cable between RC and phone/tablet.
2018-1-27
FatherXmas
The good news is, with the latest firmware and app (iOS - I have no idea about Android) OTG works great. The app remembers all of your settings now plus all of the telemetry is working.
2018-1-27
Mue
Japan
Inaccurate information.  I use OTG cable all the time and its very stable.  It doesnt increase distance or connectivity to Spark.  Only to the RC.
2018-7-19
ssakellaro
Flight distance : 28058 ft
Depends on the cable. I have OTG adapter (micro-usb -> usb) and then i use the charging cable of my phone and works perfectly (latest firmware/app version).
Be carefull some phones/tablets do not support OTG.
2018-7-20
djiuser_WFFMwgC8K3PU
Flight distance : 3830807 ft
WTH? I just bought my first Spark Dec.5th 2018. I can't get OTG cable to work at all, THE FUNNY THING is that the cable CAME IN THE BOX WITH THE SPARK FROM DJI!
2018-12-10
Why are they including cable with purchase if it isn't supported?
2018-12-10
Arcicorsa Posted at 1-27 09:55
Here's what I don't get. I just bought my first Spark, and TWO OTG cables were included in box. One for micro-usb and one for USB-C, but I can't get it to work with my Galaxy S8
2018-12-10
MartyTravels
Flight distance : 394173 ft
It worked very well the last time I tried it and I built my own OTC cable. Latest firmware and app.
2018-12-10
dencio1976
Flight distance : 10397 ft
Philippines
From where I'm from, temps is hot. OTG cable helps with getting less heat as my device doesn't use WIFI to connect. I get bad feed in the afternoon on just WiFi.
2018-12-12
Daniella3d
djiuser_WFFMwgC8K3PU Posted at 12-10 13:26
The cables that are included are not meant for that, one is for connecting the drone to the pc, and the other is for charging the RC through USB.
2018-12-19
Blu Zap
Flight distance : 41814 ft
Wow.  Thanks for this conversation.  Very enlightening.  I've had the Spark for a month now.  I had figured the cables were to connect the RC to an Android phone.  I have an iPhone 6 that works fine on WiFi.  But with WiFi on all the time the phone battery gets drained quickly.  I have a new battery in the phone, but still see a drop on only a 15 minute flight.  My thought was to use an OTG cable to connect the RC and iPhone. That would keep WiFi from draining the phone battery..  But one, I cannot find one and two, sounds like a bad idea anyway.  Thanks for all the info.
2019-1-20
