Phantom 4 Pro 01.04.0602 Update Failed
1397 9 2017-7-9
bac327
Flight distance : 681217 ft
I went to update the firmware on my P4P today and it failed. Batteries on the P4P, remote, and ipad mini 4 were all over 50%. I've tried updating multiple times, but its failed every time. Ive even tried to update using Assistant 2 on my Macbook Pro. Error code screenshot attached. Any help would be appreciated.
Error Code
Error Code
2017-7-9
Nelsonlee
Flight distance : 2779203 ft
Malaysia
Have you try using PC windows system and install the DJI Assistant 2 to try it?
2017-7-9
bac327
Nelsonlee Posted at 2017-7-9 18:00
I don't have access to a PC.
2017-7-9
andyc57
Flight distance : 184032 ft
hi reformat the sd card and try again......
2017-7-9
Nelsonlee
Malaysia
andyc57 Posted at 2017-7-9 18:26
The P4P firmware update is not using sdcard but is running DJI Assistant 2 software on your PC/Macintosh.
2017-7-9
Nelsonlee
Malaysia
I think this thread can help you to solve the problem.
https://forum.dji.com/thread-76157-1-1.html
2017-7-9
Punchbuggy
Flight distance : 573054 ft
Nelsonlee Posted at 2017-7-9 18:30
I recall that the update is in 3 parts: download, load (or something similar), and update. I suspect that whether you are updating via Assistant 2 or via GO (using RC and WiFi), the bin file is loaded to the SD Card prior to local application. It would make sense to ensure that the card is formated.
2017-7-9
andyc57
hello Nelsonlee it may sound crazy but i was having upgrade firmware issue it  was stoping at 69 % and some told me reformat the sd card and bingo it worked and yes your correct the update are done via Assistance2 my platform is a MacBook Air.....
2017-7-9
bac327
andyc57 Posted at 2017-7-9 18:50
Thanks guys. I've tried reformatting the card and that didn't work. I've also tried updating on a iphone 7 plus and Samsung Tab S3 now too.  Nothing has changed. And of course DJI's response was to try updated using the Go 4 app and to make sure my battery was over 50%. If they would have read my email they would have known that I've tried those things. Any other suggestions?
2017-7-10
bac327
Update: Somehow I was able to update via Assistant 2 program on my Macbook. Now its saying ESC error and my gimbal is not in alignment and moving around erratically.
2017-7-10
