DJI Paladin
Hi there. Thank you for reaching out. It is advised to use a mobile editor to edit with Premier, MediaEditor, DaVinci, etc. You may refer to the information below with the D-Cinelike of Osmo Pocket and DJI Mini 3 Pro.
For OP:
1. Video H.264 pre compression format: YUV420
2. The sensor input data bit (color depth) under different video resolutions;
a. Frame rate <=30, 12bits;
b. Frame rate > 30, 10bits
For the DJI Mini 3 Pro:
D-Cinelike is 10 bit, if you choose H.264, it cannot be recognized by some mobile devices. Under D-Cinelike, please check other parameters settings;
1. Photo YUV: 422
*Photo sensor enters data bit (color depth): 12bits
*Take a picture and enter the data bit (color depth) of the liveview sensor: 10bit |
