Synchronizing Flight Records Failed
4967 21 2015-5-11
gil
Flight distance : 1379308 ft
I have been trying to upload the flight records to wherever it is they go but have not had any luck.  The first window where it says "Synchronizing Flight Records...30%" gets up to 98 or 99% and then I get the what is in the second window:  "Synchronizing Flight Records Failed"  As you can see I haven't had that many flights and I have a fiber interconnection so bandwidth shouldn't be an issue.  Any ideas?
2015-5-11
Fingerlaker
If there's a flight log mode in the Phantom 3 Pilot app, I haven't found it.
2015-5-11
gil
Fingerlaker Posted at 2015-5-12 01:26
Once the DJI Pilot is open, go to "User center" and log in.
Then at the bottom of the screen click the middle icon (looks like a paper airplane and is highlighted in the photo above )
2015-5-11
Fingerlaker
gil Posted at 2015-5-12 02:21
Then at the bottom of the screen clic ...
I've been to the User page before, but never noticed the little icons at the bottom. Thanks so much Gil!
2015-5-11
jeff.wyman.mac
Flight distance : 3194669 ft
I've been able to sync successfully, but wondering what am I syncing to?
2015-5-11
gil
jeff.wyman.mac Posted at 2015-5-12 03:08
Why big brother of course!  See thread Did anybody else catch the "Big Brother is watching" language?
2015-5-11
aburkefl
Flight distance : 78612 ft
gil Posted at 2015-5-12 03:55
Why big brother of course!  See thread Did anybody else catch the "Big Brother is watching" langua ...
1984 has come and long gone - big brother is probably even bigger now than Huxley ever dreamed of!
2015-5-11
jeff.wyman.mac
Discovered that it syncs among your devices.  It would be cool if they had a desktop application to store/review stuff.
2015-5-12
DJI-Autumn
Android device?
2015-5-12
jgraham103
I'm having the same issue. Posted it a day or 2 ago here: Flight records not syncing
According to DJI-Autumn, it's been sent to R&D. Mine seems to only have problems syncing flights longer than around 15 min.
Not only is big brother watching, he's lured you into buying his robot flying machine so he can take over the world!
Until then, I'm having the most fun with this thing than I've had in a very long time.
2015-5-12
gil
Yes.  Samsung Galaxy note (SM-T230NU) Android 4.4.2
2015-5-12
edumlz
i´m having the same problem with Samsung Galaxy TAB S
2015-5-20
ReppocMike
Flight distance : 1627667 ft
Finland
edumlz@outlook. Posted at 2015-5-20 21:31
Hi! I have same issue with Nexus 9, Lollipop 5.1.1
2015-5-20
novaidk
Flight distance : 321621 ft
ReppocMike Posted at 2015-5-21 12:47
same problem with Samsung Tab S 8.4
2015-5-20
lnwpower
Thailand
same problem with sony z3
2015-6-11
PhantomAtAK
I am also having the issue with my Nexus 9 Lollipop 5.1.1.
2015-6-12
zhollid
I am also having issue with my nexus 6 running tmobile 5.1.1. Nexus 9 works great
2015-6-14
Total
Flight distance : 336480 ft
this worked for me  THREAD
2015-6-14
PhantomAtAK
Here is what I did to "fix" the "sync failed" issue.  I would not tell you my solution is right for you, and may result in destructive results to your flight record.  I frankly had only 20 flights, so I did not care if my records got wiped (they did not).  I had previous successful syncs prior to this error message, so my flight records appear to be residing/stored/backed up on the mystery cloud somewhere.
I use a Google Nexus 9 on Lollipop 5.1.1. DJI Pilot app 1.1.0 (directly from DJI site, as the Google Play app 1.0.1 is no good). My P3 arrived with 1.1.9 pre installed, no upgrade required by me.
I have been trying to clear up a serious video lag issue with my current configuration. Some have recommended  configuration changes to local video cache and/or clearing the flight log.
Additionally, I have also been getting the "sync failed issue".
Here is what I did to "fix" the "sync failed" message:
Lauch DJI Pilot app on tablet
Click on "User Center" (version 1.1.0)
At the bottom of the screen, select/click the little paper airplane looking icon in the middle of the three icons. This takes you to the "Flight Record" screen.
You should have a list of your flight records.  I then selected the setting/tools/gear icon in the top right.
I then selected "clear local cached record" (scary, will I get it back? - yes I did!)
A small option menu opened, I selected the red one "Clear All Cached Records".  My flight record page now reads "No Flight Records".  I then selected the top "sync" button.  A new sync proceeded, and all my records were restored to the page with success.  Additional clicks to the sync button now give me a success response.
2015-6-14
EmilioCid
Flight distance : 7445200 ft
Brazil
PhantomAtAK Posted at 2015-6-15 02:35
I didn´t work, and I lost my flights.
2016-12-7
MDean
Flight distance : 524272 ft
EmilioCid Posted at 2016-12-8 04:08
I didn't work for me either. But I found my flight records on my device (Android, in the DJI/dji.pilot/FlightRecord folder). All of my data is there. Just can't see it in the DJI GO app.
So, I went to HealthyDrones.com, uploaded the files, and can gather info from them. Enough to update your paper log book.
My data is there, it just won't sync.  DJI should create a way to reset the sync data to allow us to re-sync.
2016-12-7
EmilioCid
Brazil
MDean Posted at 2016-12-7 21:30
Problem solved. Now the sync works fine
2017-6-1
